Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > 4G63 DSM Tech > Tuning & Engine Management
Tuning & Engine Management EPROMS, ECU, MAF, knock, EGT, wideband, datalogging, fuel trims, etc. Read this Forum's Strict Guidelines.
Reply
LinkBack Thread Tools
Old 08-09-2007, 05:23 AM   #1 (permalink)
Proven Member
TSG59_Steve's Avatar
Region: Midwest
Classifieds Rating: (8)
Reputation: TSG59_Steve is pretty helpful and trustworthy
97 ECU in a 95, 6 bolt swap
Pretty simple question, from what I've read all turbo ECU's will work in another turbo car. I also read that I might need to swap wires. Just wondering if that's right. I've got the RRE harness if that makes any difference.
Oh and the reason for swapping in the 97 ECU... I'm finally getting DSMlink! I have a parts car, and I need a car. So I figured I'd swap the ECU's until mine came back from socketing.
Thanks guys,
Steve
____________________________
Steve - 6bolt 95 GST
Offline
Related Auctions
Sponsored Links
Old 08-13-2007, 01:23 PM   #2 (permalink)
Proven Member
Region: Midwest
Just for a follow up, I was right. All that's needed is swapping wires. Car fired right up and seems to run better on the 97 ECU then my 95 ECU. No random misfire either *knock on wood*
Offline
Old 08-13-2007, 01:55 PM   #3 (permalink)
Proven Member
Car: 04 Ram 2500 Cummins 600HO
Region: New England
Classifieds Rating: (0)
Reputation: thekellbeast is pretty helpful and trustworthy
Have you popped that 97 ecu open? I can 100% guarantee you that it's not an EPROM unit, which you need for DSMLink. I have a 97, and I recently swapped in a socketed EPROM 95 ecu with my DSMLink stuff. The car ran great for a few blocks, then the clutch went out.
John Barrett
2004 Dodge Ram 2500 CTD 325hp 600tq
Offline
Old 08-13-2007, 01:58 PM   #4 (permalink)
Proven Member
Region: Midwest
Quote:
Hahahaha, yeah Eprom's only came in the 95's. I know the 97 isn't an Eprom. I was only using the 97 ECU so I could drive my car while my Eprom was getting socketed. Capiche?
Offline
Old 08-18-2007, 11:22 PM   #5 (permalink)
Proven Member
Spyder4g64's Avatar
Region: New England
Reputation: Spyder4g64 is an unknown
You can swap the plug wires, or even the 2 blue wires on the clip of the coil pack. If you get a random misifre, IE your car turning into a WRX sounding "slug", just leave your TPS unplugged until you get your socketed unit back. This will disable the ECU from checking for Random Misfires.
4G63 powered N/A Spyder
Offline
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Page generated in 0.11805511 seconds (72.76% PHP - 27.24% MySQL) with 9 queries
