Stroker motor w/ Magnus rewired 1g cas
gsx4g64
271
3
Oct 14, 2005
Fort Lauderdale, Florida
What's up guys and gals? I am new to using the Aem Ems. I was wondering if anyone can lend me a helping hand. I have a few questions that I have not been able to find the answers to.
1. In regards to the Magnus rewire. I have heard that Dsmlink has a option that allows you to invert the injector signal without messing around with the harness or changing the pins. Does my Aem allow me to do the samething? If so, where do I go I to change that setting?
2. Next. In regards to the rewire. It also says that I will also need to change either the order the spark plugs are in or change the wiring o the back of the coils. I have gone with the coil on plug setup. Do I need to switch the two blue wires around. Or can the aem change that also?
Any help that anyone is able to give me, I will be forever greatful.
Thank you in advance.
Well, I did find out the answer to the second question. You must change the signal wires. If you don't, you will not get spark at the right time. Your won't start. Once I was able to get spark, I changed mine around, and the car fired right up.
