Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > 4G63 DSM Tech > Tuning & Engine Management
Tuning & Engine Management EPROMS, ECU, MAF, knock, EGT, wideband, datalogging, fuel trims, etc. Read this Forum's Strict Guidelines.
Reply
LinkBack Thread Tools
Old 06-01-2002, 06:12 PM   #1 (permalink)
Proven Member
Classifieds Rating: (0)
Reputation: MitsuE95GST is an unknown
fuel question
I have three questions,
1. What type of injectors does a turbo car have low or high impedance?
2. A friend of mine has a GS and wants my stock exhaust from my GST, will the entire thing fit or just the cat-back?
3. Will a 2G GST stock fuel pump work in a 2G GS car?
____________________________
http://www.extremeevolutions.com/4G64_buildup.htm
Offline
Related Auctions
Sponsored Links
Old 06-07-2002, 12:17 PM   #2 (permalink)
Proven Member
Reputation: brokeawd is an unknown
Im not sure about the other stuff, but dsm's have low impedence injectors, somewhere in the 2.3ohm-5 range. RX7 injectors have been known to be high impedence.
Im not sure why the hell you would wanna put a Turbo fuel pump in a NA car, it would drown it. The pumps may be the same but I seriously dought it.
93
Offline
Old 06-18-2002, 08:04 AM   #3 (permalink)
Proven Member
Reputation: B8SMAN16GSX is an unknown
just the cat back
wouldn't put turbo fuel pump in gs
My car is for sale. Check out my member profile for mods and what not.
Offline
Old 06-18-2002, 02:04 PM   #4 (permalink)
Proven Member
Reputation: Violater101 is an unknown
RX-7 Injectors will work ..its off a particular year...i forget off hand, but I believe its around 87 or so...the Turbo 2 model had 550 Denso low impedance injector's. I have them in my car and they run great.
I would not put a turbo fuel pump on an NT car.
I don't think the exhaust will fit, i'm sure if you look on the net from various vendors you will see different upgrade paths for NT cars, hence a totally different exhaust.
Offline
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Page generated in 0.10660291 seconds (69.12% PHP - 30.88% MySQL) with 9 queries
