ECMlink Beginning DSMLink help
tsi2fly1991
40
Dec 21, 2003
scottsbluff.ne, Nebraska
I just got my DSM LINK and I need some help. Can someone please explain how to tune ltft (long term fuel trim) low medium and high? Also how do you log long term fuel trims? Another question I've got is what menu is all this located in (ltft)? Is there any way of transferring someone else's tune over there internet so I can load it into my setup? Any help would be very helpful to me!!!
If you just bought DSMlink then you should be able to post this question in the Link forums. There will be more folks able to help you on that site. In order to answer some of your questions about LTFT, we will need to know your injector size, fuel pressure, and any other mods. You should have also gotten an install manual for DSMlink that would show you what drop boxes to access to adjust settings and also log info.
Goto DSMlink.com and click on the downloads section and download the Manual it will be very helpful to you.
