07-21-2005, 11:55 PM
#1 (permalink)
Proven Member
i nee evo 16g settings quick!!!!!!!!!!!!!!Pleas help!!!!!!!!!!!!!!!
Hey guys, I have 2g 96 gst. my mods are:
-evo 16g ported and flappered
-2.5 inlet and than 3" downpipe
-3" catback 3.5 tip
-greddy 24r fmic
-clinic 550cc injectors and safc 2
-greddy upper intercooler piping w/ type s blowoff
-2.5" o2 housing
-Injen intake routed back to blowoff valve
-dual stage boost controller turboxs
-aftermarket stianless steel valves and new seals and head gaskets.
-and of course some guages
my goal is to beat a cobra mustang and 5.0 mustangs. I hate mustang. but anyways lets get to business. i just put in my injectors and turbo. i was running 17 psi with t25. but i need new settings for the bigger monster.
im planning to run 18-20 psi. im normal street driver. Planning to go all out.
So please give me the best settings for the safc. Give me everything you know i should do to the safc.!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Offline
07-22-2005, 12:09 AM
#2 (permalink)
DSM Wiseman
Region: Midwest
Here's some basic information to get you started:
http://www.roadraceengineering.com/newafcsetting.htm
If you were planning to go all out, your injectors will not let you exploit the full potential of the EVO III. 650's, 660's or even stock EVO VIII injectors would have been a better choice. The AFC will bump the timing curve, so go easy until you log it and see if timing is being pulled at WOT in 3rd.
Hope that helps,
Andy
Offline
07-22-2005, 09:02 AM
#3 (permalink)
DSM Wiseman
Region: Tri State
This is my favorite:
http://www.racingknowledge.org/topic.asp?TOPIC_ID=1011
Also, I don't see a logger in your mod list. Better not be trying to tune without a logger.
That's when you blow shit up!
____________________________
- Nathan
Offline
07-22-2005, 11:31 AM
#4 (permalink)
Proven Member
i forgot to metion that i have 255 walbro fuel pump and 2100 act and act flywheel.
And any other tips and settings you guys recommend.
Offline
07-22-2005, 11:45 AM
#5 (permalink)
Moderator
Region: Tri State
Yes, you need an afpr.
Bruce
Offline
07-22-2005, 12:18 PM
#6 (permalink)
Proven Member
Region: Midwest
The Evo injectors are 510cc if im correct.
Offline
07-22-2005, 12:35 PM
#7 (permalink)
Proven Member
sorry but what is an afpr and where can i find it?
Offline
07-22-2005, 12:40 PM
#8 (permalink)
DSM Wiseman
Region: Tri State
AFPR = Adjustable Fuel Pressure Regulator
The 225 flows more than the stock pump, obviously. The problem is that the stock fuel pressure regulator isn't able to handle the increased flow and you end up running rich all of the time.
Anyway, all of the major parts vendors carry them, just look under fuel.
- Nathan
Offline
07-22-2005, 12:53 PM
#9 (permalink)
Moderator
Region: Tri State
You need an afpr because the fuel return capacity of the stock fuel pressure regulator is inadequate to bleed off the excess fuel generated by a larger pump like the 255 resulting in the inability in maintaining the base pressure and the 1:1 ratio between the intake and fuel pressure causing rich conditions during idle, part throttle and poor gas mileage. Most dsm vendors carries them but be careful and stay away from the B&M Command Flo.
Bruce
Offline
07-22-2005, 12:55 PM
#10 (permalink)
Moderator
Region: Tri State
Damn, got to stop taking phone calls in the middle of posting.
Bruce
Offline
07-22-2005, 01:22 PM
#11 (permalink)
DSM Wiseman
Region: Midwest
Quote:
Per Jeff at DSM Chips, EVO VIII injectors flow 600cc even though the rating is less. ALL Denso injectors flow more than their rating.
Offline
07-24-2005, 08:56 PM
#12 (permalink)
Proven Member
Quote:
Very interesting; what is he basing this conclusion on, flow tests or tuning settings?
Evo8 injectors are rated 560cc, anyway--not 510. I've been delighted with mine--best $120 I've ever spent.
EDIT>> To answer the OP's questions, the two links given above (especially the RKO link given by spyder007) will get you going. If you don't have a logger, the RKO link will be fairly useless.
My personal mods are quite similar to yours, except I have a JR fmic and 560cc injectors. My Low Thr. settings are approximately -16 across the board, and my High Thr. settings are right around -16, adding a few more % into the positive (i.e. -15 and -14) in the midrange when boost usually comes on. These settings are still fairly rich, as far as I can tell, at 20 psi. My o2 voltage is above .95 across the board.
Joe Mathews - Evo III 16g Powered
Offline
07-24-2005, 10:47 PM
#13 (permalink)
DSM Wiseman
Region: Midwest
Quote:
Originally Posted by joemathews
Very interesting; what is he basing this conclusion on, flow tests or tuning settings?.
Quite possibly both, but most likely tuning settings for deadtime and global. Although I purchased FIC 550's he told me the EVO VIII 560's were a much better bet and would have more headroom up to 600cc. If you check on some posts regarding Denso injectors, a number of people on this board, and others, mention that they flow more than their rating. I'm not sure if the rating is conservative, but I trust Jeff's information on this.
Cheers,
Andy
Offline
07-25-2005, 12:42 PM
#14 (permalink)
Proven Member
thanks guys for all the help and links, ive messed around with it and have a 30 and 80 th point. and have a couple of the settings high in the -10 and low in the -15 and 18 pounds of boost and runs awsome. i beat a wrx sti with intake and exhaust. i can feel the diffrence. thanks
Offline
07-26-2005, 06:27 AM
#15 (permalink)
DSM Wiseman
Region: Tri State
Tuning without a logger is bad!
You can put together a logger for about $150.
$ 15 palm on ebay, software is $125 from www.pocketlogger and a $5 cable.
Worth every penny!
- Nathan
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is On
