HELP! Local Track wants $10/Gal for race gas
xcelr8n
1,854
5
Jan 31, 2003
toronto,
OK, so i just called the track I will be at on Friday, and they want like 10 bucks per gallon, actually they want $3 CDN per litre to be exact...
I need a simple, cheapish mixing method of doing it myself,
anyone know anything about it?
Thanks
you can search alittle but here is your best options
1....toluene or xylene at any local paint store.....When i would run it i mix 3 gallons 93 with 1 galon toluene with 3oz of marvel mystery oil or automatic trans fluid,which lubricates...toluene is alittle less octance then the xylene...toluene is 115,and i think xylene is 117...1 gallon of one of these 2,and 3 gallons of 93 equal out to anywhere from 98-105 octane
2.....get alcohol meth injection...then you wont need race gas at all,or you could run the mix i mentioned above for total knock control on 25+ psi
www.alkycontrol.com is a sick kit which im gonna be running soon enough there is others
www.coolingmist.com
www.snowperformance.net
good luck! all these are great options,i feel your pain!
In a recent issue of Sport Compact Car, they did some testing of different octane boosters. They got a chemical analysis of each one done. The racing version of the NOS octane booster ended up be only slightly behind toluene in price per octane points gained. I have no personal experience with the stuff though, but I'd definitely consider it based on that article.
    • dhssoccer24
    • LSM
    • LSM
