Quote:
Originally Posted by TUNED GSX
I think I have the same problem cause my car when parked at idle. I hear this crackling noise from cylinder 3 or 4, I think and the car wants to die but I dont know what its is. I checked for spark on the wires and they all work. Its just that crackling misfire noise that makes the car idle between 650 & 900 rpms.
Your wires are probably arching. It's also one of the signs of ECU caps going bad.
As for the first post, trace that wire and look for cracks/breaks. Thos wires get hot, hard and brittle. Replace the whole plug with both wires if needed.
