Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > 4G63 DSM Tech > Tuning & Engine Management
Tuning & Engine Management EPROMS, ECU, MAF, knock, EGT, wideband, datalogging, fuel trims, etc. Read this Forum's Strict Guidelines.
Reply
LinkBack Thread Tools
Old 03-10-2005, 01:27 PM   #1 (permalink)
Proven Member
TSiGoesPsSsSst's Avatar
Region: New England
Classifieds Rating: (1)
Reputation: TSiGoesPsSsSst is more helpful than not
Need a little help setting up my SAFC-II(PLEASE!!)
I was wondering if anyone could give me some base settings,where the car should run half-way decent I would greatly appreciate any help at all.
Im running a PTE 50 Trim
No AFPR (I know bad,but it will change soon)
255lph walbro
650cc injectors
Thanks.Youll be helping me out ALOT
____________________________
-Dave
92 Laser RS AWD (DSM# 5)
04 SRT-4
Offline
Related Auctions
Sponsored Links
Old 03-11-2005, 03:01 AM   #2 (permalink)
Proven Member
Classifieds Rating: (0)
Reputation: HighPsiAwd is an unknown
Well I have the exact same fuel setup as you only running a GT30 56 trim. Had it wideband tuned at 11:1 at 20psi on 92 octane pump
Low Settings=
1K- 10
2k- 22
3K- 25 rest of the way up
High Settings=
3K -30
4K -30
5K -30
5.6K -28
6K -28
7K -27
7.5K -27
Good luck
95 GSX - GT40comp/GT30exh
Offline
[posts] Reply With Quote
Old 03-12-2005, 12:33 PM   #3 (permalink)
DSM Wiseman
CanadianTSi's Avatar
Region: Eastern Canada
Classifieds Rating: (2)
Yep I would agree. I would put the highs at like -25 at first to be safe and see if you can go any leaner from there.
And for the Low's...only your logger can tell you that
Tyler Webb.
123.26mph on the Stock 7bolt.
Offline
Old 03-12-2005, 11:21 PM   #4 (permalink)
Proven Member
Region: New England
guys thanks so much.I think I found out my cars problem now (see my other thread - Car will not boost over 10 psi on the 50 Trim)
My car was only drivable with +40 to 50% on the highs.and about -1% in the lows.Anything closer to zero and it did not want to move at all.It would only would boost about 6 or 7 psi then start to bog and backfire like crazy.The car mustve been running piss rich.
-Dave
04 SRT-4
Offline
Old 03-13-2005, 03:11 PM   #5 (permalink)
DSM Wiseman
Piss Rich would be an understatement...I hope you didn't damage anything by washing down the cylinder walls with so much fuel.
Tyler Webb.
Offline
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Page generated in 0.13050890 seconds (68.67% PHP - 31.33% MySQL) with 9 queries
