Hks
snipe99999
301
May 13, 2002
Hey,
I have a question about the HKS TURBO TIMER: TYPE 1 install on the
2g. I have a GST with a factory alarm. What happens
if you wire up the turbo timer and don't do the alarm
mod? Will the alarm not work at all? Will the alarm
only work after the timer shuts the car off? Will the
timer not work? Or anything else that I did not think
of. I have also got the harness that goes with the timer does this help?
Thanks for the help,
Ian
if you don't do the alarm mod then you have to wait until the car is off(not running) to arm the alarm. So the alarm still works but you need to wait by the car, defeating the purpse of the timer.
With the mod you can arm it while the car is still running.
