After upgrading to 560cc injectors the car really bucks after letting off from WOT
kobykris
240
Jul 15, 2003
fdsa, Arizona
After building full boost ~20psi the car really bucks after I let off the gas from WOT. It is kinda violent and whatnot, but it doesn't backfire or anything. The logger shows low/mid/high fuel trims all sitting at 100% and sometimes the mid/low will sit around 96%-98%.
mmine does this too sometimes, its reeally annoying and violent
im on 550
You are probably running rich. It sounds like you are experiencing rich studder. I had this problem and I had to lean things out quite a bit to get rid of it.
What are you using for tuning?
i had the same problem with my car...i have a 420a turbo..but on my car advancing the timing a little bit (maybe 2 degrees) solved the problem...just an idea for you 4g63 guys to try
Yeah I thought about that, but I figued it wasn't running rich enough to do that. I can try giving her a bit of timing tonight and see if it still happens.
