ECLIPSE4x4
- 2,651
- 8
- May 28, 2002
New Bern,
North Carolina
Ok, here is the deal.
Just finished my 6 bolt swap (2G pistons, 1G rods
I have an AGP 50 trim set-up.
Ok I can not go above 14 PSI with out atleast 4 degress (DSM Link) knock and no more than 11 degrees total timing. The knock is absolutely horrible.
I have put in a new FP, changed the knock sensor, Swapped 3.5 maf in place of the 3", upped the fuel pressure.
I put some 110 gas in there and ALL the knock went away with full 18 degrees total timing.
I am not going to accept the fact that this 50trim(ultimate pump gas turbo) can not run more than 14 PSI on 93 octane.
My question is WHERE TO NEXT. what do I need to look at.
