tbTalonES94
- 333
- 1
- Jun 23, 2002
Cedar Rapids,
Iowa
Ok here's my log.. 2nd and 3rd gear max boost was about 12psi. Mods are in profile
02s stay between .84 and .86, TPS 99.0%, High and Mid fuel trims 100%. o2 trim 100%. Please Help. Base timing is 5 and it still goes so high. Fuel pressure is at like 50 with the vacuum line off or on.....i hooked it up weird to the rail and i cant lower below that. Can i just lean it out A LOT and trick the ecu into thinking there is less air?
RPM Knock Timing
3156 0 27
3375 0 28
3625 0 26
3906 0 27
4218 0 26
4468 3 22
4812 2 21
5375 2 21
4968 0 41
4781 0 26
3781 1 24
4031 0 24
4156 0 22
4375 5 19
4468 9 18
4750 9 18
4843 8 17
5031 12 16
5281 18 15
5500 17 17
RPM Knock Timing
3156 0 27
3375 0 28
3625 0 26
3906 0 27
4218 0 26
4468 3 22
4812 2 21
5375 2 21
4968 0 41
4781 0 26
3781 1 24
4031 0 24
4156 0 22
4375 5 19
4468 9 18
4750 9 18
4843 8 17
5031 12 16
5281 18 15
5500 17 17
