ground wire for base timing? poor man's anti-lag?
quest49s
111
Sep 22, 2002
Austin, Texas
The only thing grounding out the wire to check base timing does is disable the ecu from advancing timing correct?
I would imagine it to be possible to hook this to my msd stutter box relay and have it keep base timig while on the box? Instead of advancing the timing relative to rpm.
I would hook it up the same way as the stutter box relay is setup and use the factory clucth safty switch to ground the base timing wire while the clutch is in and ungrounded with it out.
What do you guys think?
Jon
