10-13-2002, 06:38 PM
#1 (permalink)
Proven Member
which injectors???
im trying to get all the supporting mods i need for a turbo upgrade but how do i know which injectors to choose from? do i need to know what kind of turbo to get first?
so far i have a profec b, walbro fuel pump, boost/egt gauges, safc, n1, k&n fipk.
do i need anything else???
thanks in advance
Offline
10-13-2002, 06:50 PM
#2 (permalink)
Proven Member
That depends heavily on what turbo you want to go with and what your goals are. You mentioned neither.
____________________________
Justin
'03 Evolution - Garage Queen
'94 Talon AWD - New Money Pit
Offline
10-13-2002, 07:15 PM
#3 (permalink)
Proven Member
i want a turbo that can get me to 11s easy and im still doing some research about which ones to get? any good suggestions???
oh yea its going to be a daily driven car
Offline
10-13-2002, 07:33 PM
#4 (permalink)
"Running 11's easy" & "Daily driven car"...good luck, if you mean pull an 11.9 on race gas because you had a great run, ehhh sure..but 11's EASY..in street trim that is much easier said than done. Just my opinion though...Later Corey
10-13-2002, 08:49 PM
#5 (permalink)
Proven Member
ill be happy with 11.9999 as long as i can say i hit 11s.
Offline
10-13-2002, 10:58 PM
#6 (permalink)
Proven Member
you can probably do it on 550s depending on driver and weight, but 650s would be a safer bet
Offline
10-13-2002, 11:41 PM
#7 (permalink)
Proven Member
thanks for the helpful respond.
Offline
10-14-2002, 03:53 AM
#8 (permalink)
Proven Member
also depends on what you are intending on using to tune with.. different tuning standards like dsmlink, haltech etc etc require different injectors for the same turbo setup.
Offline
10-17-2002, 04:07 AM
#9 (permalink)
Proven Member
Are 1G and 2G Fuel Injectors compatible?
Quick question, since I have never pulled the injectors out of my 99 GSX (2 weeks old). Are the injectors in 1G and 2G the same? I want to upgrade the 2G (450cc) injectors to 550cc injectors.
thanks
Offline
10-17-2002, 04:17 AM
#10 (permalink)
Proven Member
Yes
Offline
10-17-2002, 07:21 AM
#11 (permalink)
Proven Member
If you are planning to hit those times I would go with 650's or 660's. It will give you a little more to work with. Make sure you have an AFPR installed first. Trust me..
Will..
Offline
10-17-2002, 12:51 PM
#12 (permalink)
Proven Member
whats afpr?
Offline
10-18-2002, 08:18 AM
#13 (permalink)
Proven Member
AFPR = air fuel preasure regulator.
Offline
10-19-2002, 11:09 PM
#14 (permalink)
Proven Member
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is On
