Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > 4G63 DSM Tech > Tuning & Engine Management
Tuning & Engine Management EPROMS, ECU, MAF, knock, EGT, wideband, datalogging, fuel trims, etc. Read this Forum's Strict Guidelines.
Reply
LinkBack Thread Tools
Old 10-07-2002, 12:14 PM   #1 (permalink)
Proven Member
Classifieds Rating: (0)
Reputation: 95talontsi is an unknown
Early 95 computer
I have what I've been told an early 95 talon. It's the tsi awd, does that mean I can use the dsmlink for the 1st gen's. how can I make sure, and I'm about to wire up a apex safc is it differenet now???
Offline
Related Auctions
Sponsored Links
Old 10-07-2002, 12:23 PM   #2 (permalink)
Site General
Car: 01 Trans-AM WS6
Region: Southwest
Classifieds Rating: (4)
You need an EEPROM ECU from a 95 in order to use a DSMlink.
____________________________
John-
Offline
Old 10-07-2002, 12:41 PM   #3 (permalink)
Proven Member
Classifieds Rating: (5)
Reputation: doug is pretty helpful and trustworthydoug is pretty helpful and trustworthy
To see if your ECU is an EPROM model, check here.
J Doug
Offline
Old 10-08-2002, 04:38 PM   #4 (permalink)
Proven Member
Reputation: shadrach is an unknown
BTW, your ECU is mounted in the center of the dashboard, behind the stereo.
Unscrew and remove the kick panel to the right of the drivers legs, and get you head up underneath with a flashlight and mirror.
If you still can't read the label, there's 2 10mm bolts in the front of the ECU, where the plugs go. Remove the center kick panel on the passengers side also, and there is one more 10mm bolt holding down the ECU on that side. Side out the ECU without removing the plugs and you can read the label.
There should be a small "E" in the lwoer right hand corner, as illistrated on both DSMLink's faq, and here:
Offline
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Page generated in 0.13661504 seconds (57.28% PHP - 42.72% MySQL) with 9 queries
