Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > 4G63 DSM Tech > Tuning & Engine Management
Tuning & Engine Management EPROMS, ECU, MAF, knock, EGT, wideband, datalogging, fuel trims, etc. Read this Forum's Strict Guidelines.
Reply
LinkBack Thread Tools
Old 03-26-2004, 11:27 AM   #1 (permalink)
Proven Member
Logue's Avatar
Classifieds Rating: (-1)
Reputation: Logue is an unknown
I think i'm running a little rich.
I logged today only my second time doing it so here it is.
14 pounds, 93 oct., 60 degrees outside. on minimal mods. intake, 1st gen bov, 1st gen head swap, and tb swap.
what do you guys think. i think i'm running a little rich at wot. if i am running real rich what do you guys suggest to fix the problem. i think i should have just done a 3rd gear pull but i didn't so here is this.
1st gear
3716 5 deg .98
4208 3 deg .98
4732 8 deg .98
5188 9 deg .98
5672 12deg .98
6180 18deg .98
6516 19deg .98
the o2s dipped to .92v when i shifted into second
4776 38deg .92v
2nd gear
4884 10deg .98
5064 11deg .98
5264 12deg .98
5444 13deg .98
5572 14deg .98
5780 16deg .98
5916 17deg .98
____________________________
6 bolted..
Offline
Related Auctions
Sponsored Links
Old 03-26-2004, 12:59 PM   #2 (permalink)
Proven Member
Classifieds Rating: (0)
Reputation: fish3rboi is an unknown
Looks rich but you need to do a third gear log. Do that and post the results..
>>Fisher<<
Offline
Old 03-26-2004, 07:07 PM   #3 (permalink)
Proven Member
Reputation: drillo99 is an unknown
your running like most stock cars due which is rich, turbo models run pretty rich out of the factory, you could lean it out with a s-afc (super air fuel control) but i would consintrate on other mods frist as leanning out your curent set up will not give you much more power.
[img]http://www.dsmtuners.com/forums/avatar.php?userid=20661&dateline=1076122661[/img]
Offline
Old 03-27-2004, 06:52 AM   #4 (permalink)
Proven Member
Logue's Avatar
yeah after i get exhaust and some other things i'm going to get and afc and try to lean things out. thanks alot
6 bolted..
Offline
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Page generated in 0.11438298 seconds (62.19% PHP - 37.81% MySQL) with 9 queries
