LAZPNO
- 162
- Aug 9, 2002
I was running around the web tonite to try and figure out what Fuel Management system to use. I saw that Buschur Racing stated that all of their cars run the HKS VPC. Well, I sat here for about an hour trying to think of pros/cons of this.
Pro: No MAS in the intake system equaling better intake air flow
Con: Is $1300 really worth that?! I can buy an AEM EMS for that (Laptop still required).
Pro: HKS GCC plugs right into it for fuel management.
Con: GCC costs like $550.
Pro: BOV vents to atmosphere.
Con: None. Everyone loves that noise and it's more accurate (from what i hear, never done this before).
Pro: Turbo/Injector size is all adjustable.
Con: Can't see one.
Plain and simple, should i get a VPC if my plans include a t3/t4 w/660cc injectors? or, Would an APEXi S-AFC be sufficient? Looking at like $1900 for fuel management, no MAS, and Speed Density system's accuracy worth it?
There are many other ways to go about Air/Fuel Management but which is best?
Con: Can't see one.
No problem on throttle tip-in though. That's adjustable on the VPC...
