need oil return line
Try extreme psi or MAPerformance. Both have multiple kits for feed and return that you put together yourself with fittings for your 16g and 2g oil pan.
Note: the return line is tough to put together in braided stainless, the pushlock style is much easier to assemble
You can use the stock line, you just have to drill the bolt holes that mount to the turbo a little wider, or get a 1g oil return line.
can anyone send me a link to one that i can buy i need 1 right away
will a 1g oil return line bolt right up?
Yes a1g will bolt right up, that's what I am using on my 16g 2g setup.
