96 taon tsi awd turbo troubles
joshua_082
Jan 28, 2011
frenchville, Pennsylvania
O2 sensor end up gettin cut on the car well runnin. I replaced it now im gettin codes po100 po105 po110 po 115????? I dont understand could it be my ecu??? It takes awhile to start then it only ides at 800 rpm???
Were you getting the codes before you replace the o2 sensor? Either way, clear the codes with the scanner tool that you are using and see if they come up again. Just because you changed the sensor does not mean that the code will go away.
No they where not coming up before.. I erased the codes and they still came back....
    • dhssoccer24
    • LSM
    • LSM
