Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > Community > Regional DSM Clubs > Tri State DSM Forum
Tri State DSM Forum New Jersey, New York, Pennsylvania, etc.
Tri State Region Homepage
Reply
LinkBack Thread Tools
Old 05-30-2008, 07:36 PM   #1 (permalink)
Proven Member
KPEclipse's Avatar
Region: Tri State
Classifieds Rating: (12)
Reputation: KPEclipse is an unknown
Help in South Jersey - 08054
Please help - anyone that has done a 6bolt swap that can make it here and help finish mine - please let me know.
I'm located about 10-15 minutes from camden. The engine is out of the car, on the stand with the head torqued down on the block. Water pump and timing needs to be done, and then alot of little things, like the alternator, oil drain, knock sensor, power steering, things like that.
Please let me know if you can come through, pm me or reply to this please!
Help needed bigtime, this car is my daily driver, and has been down for 3 months!
Online
[posts] [gallery] [blogs] Reply With Quote
Related Auctions
Sponsored Links
Old 05-31-2008, 04:32 PM   #2 (permalink)
Proven Member
ihatedsms's Avatar
Region: Tri State
Classifieds Rating: (0)
Reputation: ihatedsms is an unknown
Im in berlin, are you looking to pay for help? It is alot of work.
____________________________
Best ET 12.226, Best MPH 112.89 all on the lil 14b
Offline
Old 06-01-2008, 10:05 AM   #3 (permalink)
Proven Member
KPEclipse's Avatar
Region: Tri State
let me get back to u after tuesday - my buddy think that we can get it all done by then...
i got alot of the dumb stuff done - water pump is on, oil drain, knock sensor, and power steering..after tuesday it should be very little work, i'll let you know
Online
Old 06-08-2008, 07:23 PM   #4 (permalink)
Proven Member
KPEclipse's Avatar
Region: Tri State
ok got it started but i have a problem...number one...theres no clutch pedal pressure...the clutch either goes all the way to the floor or all the way up...i dont know how to adjust it or what the problem is
number two...one of the power steering pulleys is rubbing on a bolt, causing it to heat up and spark...i dont know wether or not to just let the pulley go, and rub the head of the bolt far enough down that it stops sparking, or how to get the bolt removed so that it doesnt spark...any ideas, or would u want to come figure these two things out...other than that i just need to tap some holes in the front of my car to hang the bumper from and im drivin on down the street.
let me know what you think
Online
Old 06-10-2008, 06:21 PM   #5 (permalink)
Proven Member
KPEclipse's Avatar
Region: Tri State
got that clutch working
today i went to take the car around the block, and everything was good except i broke one of the coolant lines i had fabbed to the turbo...car started bucking and shut off.
i plan to get it towed to a shop in berlin unless someone on here can help me with the rest...here's what my problem(s) is/were
broken coolant line(the rubber part not the metal)
like a 1500+ idle
bucking under load (but i think that was due to the bov not being set right)
too much power steering fluid(i think the rest just ended up leaking out, and thats not a big issue any more)
if you or anyone else can come through tomorrow or the next day, and fix it, and make it driveable ill throw u some cash...id rather help out a fellow dsmer than just any ol shop...let me know
Online
Old 06-14-2008, 07:46 AM   #6 (permalink)
Proven Member
Venom1515's Avatar
Classifieds Rating: (1)
Reputation: Venom1515 is an unknown
Where in Berlin did you take your car I need to get mine looked at ASAP
Offline
[posts] Reply With Quote
Old 06-14-2008, 07:55 AM   #7 (permalink)
DSM Wiseman
blcknspo0ln's Avatar
Region: Tri State
Classifieds Rating: (4)
Hey man, you got this far just finish the job up. Fix your coolant line (just run new 3/8" heater hose), fix your boost leaks (most likely causing your very high idle and shitty performance while driving, and tighten up your power steering. That's only another 2-3 hours to reward yourself with a car you fully built yourself.
~Tom
Offline
Old 06-14-2008, 12:03 PM   #8 (permalink)
Proven Member
KPEclipse's Avatar
Region: Tri State
I actually ended up fixing the coolant line, and there was a boost leak at the TB elbow, fixed that just by tightening, but the idle was still nutso, I mean it went down, but was still like 1300. Power steering I tightened, but it was still acting crazy...so I drove it out to the shop(with no front bumper lol) and they said they'll fix that in the next couple of days.
I say I still built it myself, Tom, shop just helped, very lightly I may add.
Online
Old 06-14-2008, 01:38 PM   #9 (permalink)
DSM Wiseman
Region: Tri State
Well I most definitely know you built that bitch yourself
~Tom
Offline
Old 06-15-2008, 02:35 PM   #10 (permalink)
New Member/Lurker
Region: Tri State
Reputation: TurboJoe's is an unknown
I live i northern nj i've done this swap a few times all succesfully if you need any help ill try to do my best. i know what its like to ask for help on the fourm and not get any.
Offline
Old 06-16-2008, 12:50 PM   #11 (permalink)
Proven Member
KPEclipse's Avatar
Region: Tri State
haha damn right Tom...once it's back we gotta catch up...I'm tryina get a CF hood like you too bruh!
TurboJoe - PM me. If you could come down one day, I'm sure the shop wouldn't mind if I mess with the car myself (with you) and if you could get it running right you'd be my SAVIOR man
Like I said, all thats left is the PS, and the idle(plus bucking)
After that's figured out, it's driveable, and I just gotta get that front bumper back on!
Thanks man lmk!
Online
Old 06-18-2008, 09:34 AM   #12 (permalink)
Proven Member
KPEclipse's Avatar
Region: Tri State
Oil gauge and temp gauge not working...i dont think it's a bad wire in the harness, but the oil sending unit is brand new, and idk
I'm going to just purchase a new oil sending and coolant temp sensor, throw them in and that should work just fine
Idle is still crazy, but i just saw im missing a clamp on the LICP side of my FMIC so i'll put that on, and see whats up...clean up a couple of vac lines, and go from there...
tom, you have any ideas other than the sensors of why those two gauges would'nt work?
Online
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
Who's froms South Jersey Berettamike Tri State DSM Forum 10 04-28-2006 10:34 AM
South Jersey Car Show!! 94_talon New England DSM Forum 0 01-27-2005 05:54 AM
Page generated in 0.20473289 seconds (76.82% PHP - 23.18% MySQL) with 10 queries
