Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > 4G63 DSM Tech > Cylinder Head & Short Block > Stroker Tech
Stroker Tech Stroker build-up discussions - 2.3L, 2.4L, etc.
Reply
LinkBack Thread Tools
Old 01-30-2008, 10:47 PM   #1 (permalink)
Proven Member
krummel21's Avatar
Region: Midwest
Classifieds Rating: (0)
Reputation: krummel21 is an unknown
2.3l vs. 2.4l Life Span
I'm assuming that the 2.4l will have a longer life span just because of all the benefits of the block but I was wondering how much longer that would be. Also about how long does the average 2.3l last or at least an estimate. I realize there are a lot of variables but I'm talking about a dd engine that sees redline maybe twice a day at the most.
Offline
Related Auctions
Sponsored Links
Old 01-30-2008, 10:51 PM   #2 (permalink)
DSM Wiseman
Region: Pacific Northwest
What benefits of the block are you referring to?
____________________________
-Luke
Offline
Old 01-30-2008, 11:08 PM   #3 (permalink)
Proven Member
krummel21's Avatar
Region: Midwest
I guess I thought since the deck was taller that there was less wear on the engine. I might be wrong. Either way I guess what do you guys think about the life span of the engines?
Thanks again guys
Offline
Old 01-30-2008, 11:12 PM   #4 (permalink)
DSM Wiseman
The block is taller, and the piston is taller to compensate. The piston is also larger in diameter, these two factors increase the weight of the piston significantly over a 2.3 stroker piston. As for reliability, tuning, the engine build, boost and rpm are the things that will wear an engine down, it doesnt matter if it's a 2.0, 2.3, or 2.4.
-Luke
Offline
Old 01-30-2008, 11:25 PM   #5 (permalink)
Proven Member
PieEyedPiper's Avatar
Region: NorCal
Classifieds Rating: (1)
Reputation: PieEyedPiper is extremely helpful and trustworthyPieEyedPiper is extremely helpful and trustworthy
To further the idea the OP is going for,
What is the difference in rod angle between the 2.3 and 2.4?
I think that knowing the relatively extreme rod angles produced in a stroker setup, the OP was inquiring as to which of the two variations have a more extreme angle, and thus more cylinder wall/piston wear.
Are you indicating that rod angle, too, is the same in both designs because of the changes in the size of the pistons that compensate for the taller block?
CB
'98 GSX
Offline
[posts] [gallery] [blogs] Reply With Quote
Old 01-31-2008, 07:45 AM   #6 (permalink)
Proven Member
TunaTalon's Avatar
Region: Midwest
Reputation: TunaTalon is pretty helpful and trustworthyTunaTalon is pretty helpful and trustworthy
The 2.3L with a 100mm crank in 4G63 block and the 2.4L 4G64 have the same stroke and the same rod length. The rod angles are the same. The Velocity profiles are the same. Side loading friction is the same.
With stock pistons the larger pistons of the 4G64 does indeed produce more loading on the main bearings.
To get the benefit of the higher deck of the 4G64 you can use stroker pistons and long rods.
As always, I’m still pushing http://www.kidzuku.com/StrokeOrNot.pdf as a place to learn more.
Maurice G.
98 TSI Stroked and Stalled
Offline
[posts] Reply With Quote
Old 01-31-2008, 10:21 AM   #7 (permalink)
Proven Member
krummel21's Avatar
Region: Midwest
The reason I ask is that the engine I'm looking at buying has 12000 miles on it which I know isn't a great amount but I want this thing to last a while since it's a large investment. With the extra forces the 2.3l puts on the 2.0 block how much does this shorten the life span? I would think a little, even if it is tuned perfectly. With it being a dd and only seeing redline 2 times a day would that engine last over 100,000 miles or even 150,000 miles or is that almost impossible. I mean the rings would have to wear out sometime sooner than a 2.0 with the extra side load correct?
Under the same conditions is the life span of a 2.3l considerably less than the life span of a 2.0?
Would you buy a 2.3l that already had 12000 miles on it or is there a lot of problems coming soon?
Thanks,
Krummel21
Offline
Old 01-31-2008, 10:38 AM   #8 (permalink)
Proven Member
TunaTalon's Avatar
Region: Midwest
While your mileage will vary depending on how you care for and drive the car you can expect the same wear from the 2.3L or the 2.4L. And yes the longer stroke engines have more side loading friction and can be expected to wear faster than the 2.0L. To put that in context the cylinder walls in my 4G63 were showing no signs of wear after 183,000 miles bathed in Mobile One and hitting red line two to four times a day as a daily driver.
Side loading friction can be reduced somewhat by using lighter pistons and rods. I went with Wiseco and Eagle. After I put 183,000 more miles on my 2.3L stroker there will probably be some visible wear.
Maurice G.
Offline
Old 01-31-2008, 07:04 PM   #9 (permalink)
Proven Member
krummel21's Avatar
Region: Midwest
Alright that makes me feel better as long as the thing isn't only going to last 60000 or 70000 I'm ok. He used a Weisco/Eagle set-up which I'm assuming is an alright set-up. You also think the bearings will last that long then?
Offline
Old 01-31-2008, 07:45 PM   #10 (permalink)
Proven Member
Region: Rocky Mountain
Classifieds Rating: (5)
Reputation: stockfornow is an unknown
The bearings will last a while, as long as you don't rev it up too high.
Oleg
Offline
Old 02-01-2008, 07:10 AM   #11 (permalink)
Proven Member
TunaTalon's Avatar
Region: Midwest
Quote:
In a street driven car the balance shaft bearings will wear out before the main or rod bearings. That is of course if the balance shafts are still in there.
At 183,000 miles my original main and rod bearings were in “like new” condition but the balance shaft bearings were the near end of life.
For my stroker project I upgraded to ACL tri-metal bearings for a little more of a warm fuzzy feeling.
Maurice G.
Offline
Old 02-01-2008, 09:29 AM   #12 (permalink)
Proven Member
Region: Southwest
Classifieds Rating: (2)
Reputation: snailspool is an unknown
Quote:
Thats some good reading!
Offline
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
T25 life span deeez2g Newbie Forum 6 02-16-2007 10:07 AM
2.4l / 2.3l?? NeoStreamGSX Bolt-on Tech 10 10-20-2004 08:50 PM
life span of a turbo? Mr. Talon Newbie Forum 5 07-18-2003 01:51 PM
Life Span On Motor Mounts & Transmission Mounts? RacerXXX Newbie Forum 3 06-29-2003 07:31 AM
Average turbo life span? Ludachris Bolt-on Tech 24 07-30-2002 09:30 AM
Page generated in 0.18086195 seconds (81.73% PHP - 18.27% MySQL) with 10 queries
