Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > 4G63 DSM Tech > Cylinder Head & Short Block > Stroker Tech
Stroker Tech Stroker build-up discussions - 2.3L, 2.4L, etc.
Reply
LinkBack Thread Tools
Old 08-13-2006, 05:25 PM   #1 (permalink)
Proven Member
Region: Southeast
Classifieds Rating: (0)
Reputation: black91awdturbo is more helpful than not
2.3l help
I have a quick question for you guys, this will be my first stroker all my other build ups were 2.0's. And looking around I see that some people are using stroker style pistions for there 2.3l while others are using normal pistions and rods for there 2.3 with the 100mm crank. So my question is this if you dont wanna use the stroker pistions do you have to use long rods? Or can you just use the normal pistions and rods and the 100mm stroke give you the 2.3l? Just so you know I have a block punched .20 over this is going in thanks for the help every one!
Offline
Related Auctions
Sponsored Links
Old 08-17-2006, 10:59 AM   #2 (permalink)
Proven Member
fourreGsixty3's Avatar
Region: New England
Reputation: fourreGsixty3 is extremely helpful and trustworthyfourreGsixty3 is extremely helpful and trustworthyfourreGsixty3 is extremely helpful and trustworthy
For 2.3L strokers, you use a 4G64 crank, stock 6-bolt length rods, and stroker style pistons. 2.4L strokers and I believe 2.1L de-stroked use the "long rods". You need the 2.3L sroker pistons though. So to sum it up http://www.slowboyracing.com/shop.php?sid=&cat=2553 , there you go just click on what stage you want, and it tells you whats included. I would recommend stage 2.
Dustin
____________________________
-Dustin-
92 TSi
92 TSi AWD *Dark Star*
Offline
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Page generated in 0.10103703 seconds (62.05% PHP - 37.95% MySQL) with 9 queries
