Viper 791xv Wiring how to
socalnicedude
Jun 6, 2007
San Diego, California
okay i just got this setup for my 2g GSX auto and i want to put it in this weekend but at this oint im doing it blindly. does anyone know where i can get my hands on a wiring how to or somethnig. thanks crew.
I live in vista so if ya need help pm me and yes i do installs for a living
12volts white + ignition harness
Starter black/red + ignition harness
Second Starter
Ignition black/white + ignition harness
Second Ignition
Third Ignition
Accessory blue/black + ignition harness
Second Accessory
Keysense
Power Lock brown/white - driver kick, door harness
Power Unlock brown - driver kick, door harness
Notes: To unlock only the driver door on models with keyless entry, use brown/blue (-) at the relays behind the radio.
Lock Motor blue/black 5wi driver kick, door harness
Unlock Motor blue/red 5wi driver kick, door harness
Parking Lights+ green/white + driver kick, harness to rear
Parking Lights- green/white - headlight switch
Notes: Found in a gray 20-pin connector.
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger red/green - driver kick, harness to rear
Notes: To avoid the dome light delay use red/white(-) at the door open indicator at the instrument cluster. The red/white will also catch the rear hatch.
Dome Supervision use door trigger wire
Trunk/Hatch Pin red/green - driver kick, harness to rear
Hood Pin blue/black - fuse box
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm green/yellow - driver kick, door harness
Notes: Meter this wire while turning the key in the driver door key cylinder.
Can also use the passenger door key cylinder which is red/blue (-) in the passenger kick, door harness.
Factory Alarm Disarm green/white - driver kick, door harness
Can also use the passenger door key cylinder which is brown/red (-) in the passenger kick, door harness.
Disarm No Unlock see factory alarm disarm
Tachometer white ac instrument cluster or PCM
Notes: The PCM is located on the drivers side of the engine compartment or behind the center of the dash depending on motor.
Wait to start
Brake Wire green/white + brake pedal switch
Parking Brake
Horn Trigger green/black - horn switch
Memory Seat 1
Memory Seat 2
Memory Seat 3
