talontsi02
- 204
- Feb 3, 2005
Redlands,
California
ok heres the thing.. i was bored one day and decided to paint my valve cover.. so i took it off.. cleaned it.. painted it.. put it back on and then drove it it was SLOW and whenever i pushed it more then normal driving it lacked power.. then id push in the clutch and it would die.. but when i drove it normally without pushing it, it wouldnt die.. when i took it back home i realized i cracked the valve cover due to lazyness and not paying attention to torque specs. (oopsy) so then i jbwelded it and it stopped leaking oil.. but then now i have a clunking noise at around 3rpm.. and i still have a complete loss of power.. ive checked all possible "simple" solutions i believe.. but the car is getting slowly worse and wants to keep dying.. i unplugged the battery for about 5min to reset the ecu and then tried to start it and it wouldnt even hold an idle till about 1min later of me holding the gas.. i have no clue what the hell i did but im pissed that i somehow ####ed up my car just by wanting a different color valve cover.. someone please help.. im completely ####ing lost other then going to buy another valve cover.. thanks..
??? meaning is it ur head or ur bottom block? if its ur Bottom Block i think ur Balancers making noises...
well the thing was that sand from the sandblaster got into the oil and f'd everything up.. i washed it out and took the air compressor and blew it out.. but still some got through
