clipse this
- 0
- Nov 11, 2003
tuesday night, it was raining pretty hard, I drove my 1991 mitsubishi eclipse gs-turbo home from work, about 25 miles. The car drove fine, idled fine, no problems what-so-ever. I got home, let it idle about 1-1/2 minutes, then shut it off. Nothing out of the ordinary. When I went to start it up 15mins later, it wouldnt start. It cranked, and then it turned over but it was like i let go of the key too fast, because it stalled. So I tried to start it again, all it did was crank. It cranked normal, wasnt slow or anything, just like normal. Anyways I eventually pushed it into my garage and checked under the hood. When I went to take my keys out of the ignition after pushing it in, I noticed a rapid ticking coming frm behind the radio. When the key was in "Start" position, I would hear this noise, and it went away as soon as I would turn the key to "off" position. Anyways I decided to check the plugs and the fuel lines first. All 4 ngkbpr7es plugs sparked fine, and fuel came out of the fuel regulator. But the car would not turn over. The next night I sprayed starting fluid into the throttle body, and cranked it, and the car started right up. I drove it about 10 miles, on city steets, to the highway, and then back to my house, no problems at all. When I shut the car off, everything was normal, went to turn it back on, wouldnt start, only cranks. The ticking went away and that isnt there anymore. Even after spraying more starting fluid in the TB, wouldnt start. I went out and got some ngkbpr6es plugs, and that didnt help any. I replaced the injectors with injectors from a 90 laser 1.8 n/t, I read in the service manual that they are the same for the 2.0 engine too. Nothing worked, So I just swapped the computer from the laser (to see if my computer was the problem) and tried to start it, but i think the battery is pretty much dead because it cranked slow and wouldnt start. The computer I took out of my car smelled very faintly of fish. I'm all out of ideas and Nobody else I talk to seems to have any idea why this car could run perfect 1 minute and then 15 mins later not run at all. Any ideas? The car cranks, there is spark, it is getting fuel, it is getting air, but wont start. please help!
