Car cranks but wont start :(
Posted by 1990talondsm, Oct 8, 2010
Please Support Extreme Turbo Systems
  1. 1990talondsm
    1990talondsm Proven Member
    86
    Joined Aug 3, 2007
    slidell, Louisiana
    I was driving my car the other day and getting on it. When I let off and started cruising the engine just died. The timing belt didn't break and it is still in time. I am getting no spark and the fuel pump wont turn on but did shoot out fuel with fuel line disconnected and cranking the car. Does anyone know where the fuel relay is cause my Manuel doesn't tell me and how do you tell if your ECU is bad.
    Log in/Register to remove ads
    My DSM:
    Loading...
  2. DSM1G90
    DSM1G90 Supporting Member
    4,830
    54
    Joined Apr 6, 2008
    Nampa, Idaho
    Pump does run when the starter is engaging - why you got fuel out while starting and stays on after the motor has started
    It doesn't say anything like that in the manual and I'm sure that your ECU took a dump .. like mine did when my car did the exact same thing-suddenly died at an intersection and had to have it towed home.
    -good luck . DSM
    Loading...
  3. 1990talondsm
    86
    Joined Aug 3, 2007
    slidell, Louisiana
    Do you know how to tell if an ECU is bad or how to test a crank sensor. When cranking the car usually displays some oil pressure cause the motor is turning, same with RPM but it is not showing either.
    My DSM:
    Loading...
  4. VisegripMech
    VisegripMech Proven Member
    79
    Joined May 29, 2005
    Riverside, California
    If you still have the stock pretend "Boost gauge" hooked up, it should move to zero when you turn the ignition to on. If you remember it working before and now it doesn't move, it's probably the ECU.
  5. chenk18
    chenk18 Proven Member
    72
    Joined Oct 5, 2009
    Chattanooga, Tennessee
    Or you could always open it and see if anything looks bad. And the fuel relay is located next to the ecu.
  6. 1990talondsm
    86
    Joined Aug 3, 2007
    slidell, Louisiana
    OK I check the boost gauge and it is not going to zero. I have already replaced the stock fuel relay then. It was just called something else when I got the part from Mitsubishi.
    My DSM:
    Loading...
  7. hectorjr
    hectorjr Probationary Member
    22
    Joined Feb 15, 2007
    Mission, Texas
    my car did the SAME thing. It was the Crank Position Sensor. it controls spark on these and most mpfi cars. id get one from Mitsubishi, hope this helps..:mrt:
  8. steve
    steve DSM Wiseman
    12,420
    358
    Joined Feb 3, 2002
    St. Charles, Illinois
    I think your talking about the MPI relay.
    When you first turn the ignition on the ECU should turn the CEL on for about five seconds and then turn it off. On the turbo cars it also moves the "boost" gauge pointer to zero and holds it there until you start cranking. While cranking the pointer should move to the vacuum side and if the engine starts remain there while idling, if the car doesn't start it should move back to zero when you stop cranking.
    If your ECU doesn't do this it's not running and it time to figure out why, nothing else interesting is going to happen until the ECU is working.
    There are a bunch of posts by me on checking the operation of the MPI relay as it applies to powering the ECU. Here's an example. http://www.dsmtuners.com/forums/newbie-forum/381070-ecu-problems.html
    If the relay is functioning then it's time to look at the ECU since the caps fail on all of them and can cause the ECU to fail.
    My DSM:
    Loading...
  9. 1990talondsm
    86
    Joined Aug 3, 2007
    slidell, Louisiana
    Thanks for the great help wise man. Ill check out your thread.
    My DSM:
    Loading...
  10. 1990talondsm
    86
    Joined Aug 3, 2007
    slidell, Louisiana
    I went and got a new 20 amp fuse for the MPI next to battery. When I turned the car on everything worked for a second then the fuse blew. Any suggestions where to start looking cause my Manuel doesn't give a good wiring diagram.
    My DSM:
    Loading...
  11. 91Bomb
    91Bomb Proven Member
    801
    5
    Joined Jul 15, 2003
    US, New Jersey
    Open ECU and look/smell on both sides of the board for burnt black gooey stuff leaking around the capacitors. This is a common problem for 1g ecu's that came with subpar caps.
  12. steve
    steve DSM Wiseman
    12,420
    358
    Joined Feb 3, 2002
    Blown ECU is one thing that could cause you to pop MPI fuses, but so can wiring shorts, bad MAF, bad CAS, or less likely problems with the solenoids, ISC, and injector resistors.
    My DSM:
    Loading...
  13. 1990talondsm
    86
    Joined Aug 3, 2007
    slidell, Louisiana
    I traced the wires from the MPI and non are split or shorted that I can see. I have a GM MAF so I will have to check the voltage there. I took the ECU out and where one of the capacitors is the is a little brown but nothing crazy. I will try to post some pics of it.
    My DSM:
    Loading...
  14. Tyeler18
    Tyeler18 Proven Member
    1,988
    43
    Joined Dec 16, 2008
    Casa Grande, Arizona
    Like stated. Sounds like your ecu is fried.
    My DSM:
    1990 Eagle Talon TSi AWD
    Road Race Build
    GT30   manual
    1998 Mitsubishi Eclipse GSX
    Autocross Build
    16g   manual
    1991 Mitsubishi Galant VR-4
    Road Race Build
    GT35   manual
    Loading...
  15. kawgomoo
    kawgomoo Proven Member
    117
    Joined Jan 19, 2010
    Va Beach, Virginia
    ecu is bad bud.
    the caps should be shiny, not discolored at all.
    trying rebuilding the ecu and see if that helps.
Share This Page
Loading...
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts Morrison Fabrication & Design OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
