Pilot Short Throw
TalonR
115
Mar 4, 2003
Oceanside, California
Has anyone put a Pilot short throw shifter in a 94 DSM, if so what were the results. What was the throw % of it...Just curious, I am getting sick of this long throw stuff.....Thanks:thumb:
No one has any clue.......k, well heres another question???in reguards to cutting the stock shifter down, is it as safe as installing a short throw???Has anyone done it, if so what are the results??Thanks:thumb:
Originally posted by Defiant
Track down ArcticTSi.
defiant is correct I am running this unit. I highly reccomend it. A little on the spendy side if I recall correctly but well worth it. The throw is roughly 35% less. The short throw is accomplished by shorting the shifter as well as changing the geometry(shape/angle) of the actual shifter. I also have new shifter cables,symborski bushings and a greddy weighted knob. helps to slam the gears. But the shifter itself is overly built, large welds and thicker than stock in some spots. If I recall correctly they are similiar to the Mofugas/Rollhard ones. Pilot just bought the units after the formentioned shops went under. The shifter sat so low in the console I had to remove the shift boot and trim the shift ring that holds the boot in place to keep from smashing my fingers. worked great, just use a dremel.
couple pics, they are old since it is one of the first mods I did.
Jose
ArcticTsi
  • For sale JMF Coil Pack Bracket
    JMF Coil Pack Bracket. Buyer pays fees/shipping to the lower 48 states. You must be registered...
    • elocneas
  • For sale 2g Eagle talon headlights set
    Talon headlight set no broken tabs
    • Lonestardsm
  • For sale 2g Stock 2G BOV
    Stock plastic 2G BOV. Removed years ago (probably 2001...). Figured someone might want it...
  • Wanted ( 2g )Wanted OEM radiator fans
    Radiator cooling fan (driver's side)
    • LA_gst
  • Wanted 2g 2g DC sports front strut bar
    Looking for 2g DC sports strut bar
    • Haydn124
