Power Slot rotors for a 1998 GSX
Maximuscr31
136
9
May 10, 2003
Afton, Tennessee
These are great rotors. A pain to put on but worth it.
Me and James hitch spent 6.5 hours last night putting these. If we would have had all the tools we needed with us then it would have been only about 1-2. The main problem was we dont have tool to remove my gorilla lug nuts. A 17mm deepwell will fit but unfortunately that was the one socket neither one of us thought to bring. So we made a 35 min trip to walmart. On top of that the support jacks we had were to freaking big and took a little bit to work around.
Also a side note you will need a 17 mm socket for the calibers on the front and 15 mm socket on the rear to get them off.
The next hardest part was getting the rotors off.We had a pull kit to thead the holes on the rotors and pop them off.The only problem with this was these things were heavily rusted and corroded. We evenly went back and forth tightening them down while hitting them with a hammer. We also sprayed about a half a can of pb blaster on them. They finally popped loose but at the expense of warped and twisted pulling bolts.
This was a pain on both sides.
The back came off very easily.Just a few taps of the hammer and they popped off.
MAKE SURE YOU HAVE THE EMERGENCY BRAKE OFF WHEN REMOVING REAR ROTORS OR THEY WILL NOT COME OFF.
Don't ask me how i know this
Overall was a easily installation. Pretty straight foward and follows same procedure as normal rotor installation. Make sure you do have the bolts to pop off at least the front rotors or you wont get them off.
I have noticed quite abit more stopping ability and no more shimming. My breaks are still settling but stopping is constantly getting better everytime I hit the brake.
Well worth the 300.00 to do the whole car.
Thanks for the help James
I also posted this in the diy forum.I am posting it here so if anyone needs help or to discuss the process i will be more than happy to discuss it.
MAKE SURE YOU HAVE THE EMERGENCY BRAKE OFF WHEN REMOVING REAR ROTORS OR THEY WILL NOT COME OFF. Don't ask me how i know this
I'd like to know how you found that out.:D Just kidding.:p
What kind of pads did you use? You DID change the pads, right?:confused:
yes and no :)
I got metal master on the front and some cheapies on the rear. I am thinking about going with greenstuff pads all the way around. Also I discovered that I accidently hit my brake shield with a hammer and is barely touching my back right rotor. Just enough to scrape and drive me crazy. ;)
