RedEclipseGS
- 265
- 0
- Jan 9, 2003
Does anyone know how or have any plans for making some "home Depot" mods or homade mods for a 2g eclipse GS any help would be appreciated cause im new at this and low on cash.Follow along with the video below to see how to install our site as a web app on your home screen.
Originally posted by White96Eclipse
also you can remove the rubber stopper from behind the gas petal that way you can go full throttle instead of 89%.
Originally posted by 1TuffRS
if you take that stop off, your throttle plate will go past being flat and actually block the flow of air going into the engine, so dont do that. some free mods for the 2Gs would consist of, taking the stock air box and drilling 2.5" holes in it using a drill with a hole saw bit. Note: This should be done in front of the filter, as in the part closest to the fender. Another mod is to use PVC piping to make a CAI, the most expensive part is buying the filter which is about 40 bux, Ive done both in the past, but if you buy a cheapo CAI off of ebay you will see larger gains. I suggest you save your money and come up with 80bucks for one. If you want to see the write up for all these mods, go to www.2gnt.com home page
