Review: 16g w/ kit from turbochargers.com
NewB2dsm
910
4
Jun 25, 2002
St. Louis, Missouri
I purchased the special from them the 699 w/ kit for 2g. I finally got it installed, and its a very good deal. The only problems i had was the oil feed line you have to dremel away 2 brakets to get it to fit. Also the J-pipe they provide is not right. The bolt on the upper side of the 2 bolts does not fit b/c the weld at the bottom does not allow it to seat "strait" so it goes in at an angle you have to dremel it down to get it to fit. I also had my 16g ported and a 34mm wategate flapper put it. Pretty easy and turbocharges.com is a great company i have no complaints exept the j-pipe. Fast shipping and good packing and a great price. STock exhaust sucks and will be getting new exhuast very soon but at 11psi its much faster than my old t25. Just thought i would share in case you were thinking about getting it and didnt know if you should or not. i give it a 9 out of 10 just beacuse the j-pipe.
Great buy.
Hey ! Happy to help ........ Thanks for letting me know about the J-pipe
issue...... I'll be sure to call Buschur & let them know that the J-pipe desighn is messed up !:D
Wade
it really didnt take much dremeling to get it to fit its just the weld around the flange that the bolts go though was a little to big and to get the bolt to seat flat, so it didnt tear up the threading in the turbo housing you had to dremel down the weld just a tad. Really was not that big of a deal but was anoying when your so close to finishing then find that you have to pull out the dremel again:D and the only part that made me upset was that i paid for somthing and it didnt fit just right. But other than that it is great no complaints but that. And now i know its a buscher j-pipe :)
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
  • Wanted [WTB] Hyundai 4g63 inner valve cover bolts
    Looking to source inner valve cover bolts for a Hyundai 4g63 valve cover
    • TheDude236
  • For sale 2g VRSF 2g FMIC.
    Bar and plate. 28x10x3.75. 2.5 inlet and outlet. 36.5 on center inlet and outlet Pretty...
  • For sale 2g Eclipse/Talon Passenger Side Fenders
    95-99 Eclipse/Talon Passenger Side Fenders
    • Sdcryan1
