need info on a t-25 to 14B swap
Status
Not open for further replies.
ImportWarrior
308
Jan 18, 2004
Rochester, New York
is the 14B a straight swap in to a second gen or is there a special kit needed and pipes and such?
or can i just swap it out and use all the same stuff from the T-25 on the 14B?
i have done this swap and its easier then i thought, i used all my old lines, just a little carefull bending of the lines to fit, but make sure you don't pinch them... and u will need a new ic piping from the intercooler to turbo cause your turbo outlet will be in a diff position and will stretch out the stock line..... other then that it just bolts right up
Status
  • Wanted 6 bolt NT water pipe
    • chrisman287
