Another "Bolt-on" exh. housing for Garretts?
silverbulletAWD
126
Aug 3, 2003
Holland, Michigan
I just saw this on ebay. Did a search and haven't seen anyone talking about it.
Anyone seen these yet?
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=2471473330&category=33742
I just noticed this one in particular is being sold out of Muskegeon. That's about a 1/2 hr. from me. hmm...
Looks like the A/R might be a little smaller than a PTE but I like the 38mm wastegate and adjustable arm. Although, a bolt on arm could be trouble too.
Andy
I thought AGP was using the PTE housing for their RS turbos. Maybe not... but I have a PTE hybrid here and I'm sure this is not the same.
no they use one just like that but a couple times they were waiting so lon for the usual exhaust hosuings that scooped up some from pte and used those to fill some backorders
Punctuation? I think not.
The bullseye housing is not new. Its been available for about 2 years now. AGP has used it extreme turbo uses that housing also.
Originally posted by GSX4LIFE
Yeah, the old Bullshit housing. Seems a bit better than the PTEs. It's made out of stainless, and it is an on center housing, like a Garrett. But, will a person see much gain? Not likely.
Your statements are not quite true.. These are available in a Stainless steel the one on Ebay is a High Grade steel. Also this is a tangenal turbo not an on center.
I have one of these housings in my car. IT is mated to and HX35 Holset turbo. I get full boost before 3800 rpms. That is with a turbine wheel that is compareable to a stage V garrett.
There are also several turbo shops that use these housings and I have heard that a shop made 602whp with a GT30R turbo and this housing, so it can flow.
One more thing. When I says that it the inlet is the same size as a 7cm mitsu that is not correct. IT is in reality a little bit bigger. Not really a big deal.
I have one of these housing on my car too... it is supposed to be around a .5x ar...
The only complaint I have is it is somewhat heavy probably 2 or 3 pounds more than a normal housing.
It moves the turbo out and leaves room for bigger compressors.
