Venting BOV trick!!!
Status
Not open for further replies.
herovueboi
422
Dec 8, 2003
Akron, Ohio
Well, after a week of venting to the atmosphere, I have something to share. When venting, unpluging the pipe from the BOV to the pipe to the turbo. My car does not stall, yet the lights ticker on and off. For the fix, I adjusted the idol screw up more and now, after a week of testing, it doesn't even come close to stalling out anymore and I get the true sound of my 1g BOV. Oh yes though, I think this has something to do with if you have an auto/manual. While in Nuetrul, chances of stalling is much greater. Staying in gear will help not stalling out. I would like to experiement on my friends 97 GS-T and I will post the results. Well, I have not tried this on anyone elses 1g DSM, so i am not certain it works. I just wanted to share that I think I have found out why it stalls out.
Results: 1g automatics will not stall if you adjust the idol screw to raise the idol while venting to the atmosphere, while leaving it in gear.
Forgot to mention, I have noticed slight loss of throttle response.
Thanks!
Thanks!
Its still gonna make you run rich between shifts and drop your performance, so it doesnt really matter whether it doesnt stall.
so far, i still have not noticed change in the amount of gas i use, still 200 miles on a full tank, like always.
Status
  • For sale 2g 2G AWD Fuel Level Wiring Harness
    2G AWD Fuel Level Wiring Harness $35 + shipping and paypal fees* removed from 97 TSI AWD * all...
  • For sale 2g 2G OEM Passenger Door Handle
    2G OEM Passenger Door Handle $25 + shipping and paypal fees* the seal and two mounting bolts...
  • For sale 2g 2G OEM Interior Silencer Pads
    2G OEM Silencer Pads $20 + shipping and paypal fees* these go behind the plastics to the left...
  • For sale 1g 90 Oil Cooler
    90 OEM oil cooler with custom lines. Takes 18x1.50 mm fittings at the housing. Fits in a...
  • Wanted 2g 2G FWD Fuel Filler Rubber Hose
    Decent condition FWD fuel filler hose.
    • kyler021
