Stock t-25 still on, install o2 elim exhaust vfaq! Replies before posting in tech plz
98RedGs
6,239
7
Sep 14, 2002
Bogalusa, Louisiana
Tools Needed:
1. Pliers
2. 2 10-16mm sockets+wrench and also the same in wrenches if you have them.
3. 22mm Open-ended socket wrench (or an o2 sensor socket)
4. Breaker Bar (can use other wrenches also)
5. P.B Blaster (or another type of rust removal spray)
6. A way to suspend the front end of the car somehow (I used ramps)
7. A very big vocabulary and the ability to curse uncontrollably.
8. Two 3” exhaust clamps.
Parts Needed: (I replaced mine)
1. o2 Housing to turbo gasket
2. Manifold to turbo gasket
3. New o2 sensor (If you feel it needs to be replaced)
Prepwork:
1. Drain the Oil and Coolant, also remove your MBC if you have one already.
Steps:
1. Get the car suspended in the air however you choose to (jacks/ramps) and get the oil and coolant drained out of it.
2. Unplug the mas plug from the mas. Then unscrew the dump-tube from the intake and disconnect the intake from the turbo’s inlet. Now remove the other lines that are connected to the intake
Pic Engine Shot Before Removal of Intake and lines.
3. Removal of the upper and lower heat shields is next.
Pic of the heat shields.. These weren’t that hard to remove at all. Once you get them removed spray your PB BLASTER (or whichever rust penetrating fluid you chose) on the four manifold to turbo bolts on the top of the manifold, let it sit and continue to the next step.
4. Disconnect the lower intercooler piping from the sidemount and from the turbo itself and remove.
5. Disconnect the electronic plug to the drivers’ side radiator fan and then remove the 4-10mm bolts that hold it into place and lift the fan UP and out of the way. It was easier for me to move around by unbolting BOTH fans. So you may would rather get rid of both rather than just one of them also.
6. Follow the wire that is coming out of the o2 housing and disconnect the plug from the side of the engine. Once that plug is disconnected follow it back to the o2 housing and grab your o2 sensor socket or 22mm wrench, PB BLAST the o2 sensor in that socket and then attempt to get that o2 sensor out. Once its out decide if you want to replace it of if you can reuse the one you already have.
Pic of the wire that follows to the side, it runs over the upper head shield.
7. This step is actually pretty easy also, unbolt the bottom oil line that goes from the oil pan to the turbo itself and also unbolt the downpipe from the o2 housing. Unbolt the downpipe from the cat and then drop the downpipe out of the way. (Removing the oil line from the turbo and from the oil pan made my install a little easier because it then wasn’t in the way at all)
Unbolt the downpipe from the o2 housing and the oil feed line from the bottom of the turbo
8. Time to remove the oil feed line from the oil filter housing and from the adapter midway through the pipe. BE GENTLE WITH THIS LINE! IT WILL BREAK!. Grab two open-ended wrenches with one to hold the adapter in place and one to move the smaller connector that screws into that adapter. (The adapter will not move!) Hold the adapter in place and now turn the small connector, it may put up a fight but remember that only one end will be turning. Once you fight this line and it finally gives in and comes undone. You will be removing the coolant lines from the turbo itself. Fun Fun Fun!
9. Look right by the intake port on the turbo and you should see two small rubber lines that connect into it. Grab your pliers and press on the clamps that hold the rubber tubes in place. Pull the clamps back and get ready to disconnect these small tubes from the turbo. I HOPE YOU GOT PAN TO CATCH SOME FLUID! Radiator fluid will pour out of these two pipes and you can take the radiator cap off to speed up the draining process actually.
10. Remember those 4 bolts that you sprayed with PB BLASTER earlier in the steps? Time to remove those. Look to the top of the exhaust manifold Top of the manifold pic. Get your breaker bar if you have one or something to put some extra torque into that ratchet and get those 3 bolts out! Once you got the 3 bolts out you now have one “nut” to remove. Find someone (or something) to suspend the turbo underneath and unscrew the final “nut” to lower the turbo down. Catch it and wiggle it out of the way. Unbolt the o2 housing from the turbo and you can now get ready to install your new exhaust.
11. If you’re installing a turboback o2 eliminator exhaust (which is what this walkthrough is for) then connect the o2 eliminator downpipe to the turbo and put it back up into place. Get the stud lined up and put it back up into place (this may be a lot of work since you have the downpipe connected to the turbo now). Don’t forget to put the gasket back between the manifold and the turbo itself (It’s a metal gasket). o2 Eliminator Exhaust Installed
12. Put oil back into the car and then coolant also. Connect the middle piping to the downpipe and put it in the exhaust hangers. Now connect the rear section of the exhaust and get everything snug. If you want for extra security (sense of mind) install one exhaust clamp where the downpipe meets the mid-pipe and where the mid-pipe connects to the rear section of the exhaust.
13. Now you can check for leaks if you want. The way I checked for leaks was to spray water as my friend revved the car up to 3000 after the initial warm-up of the car. I sprayed the water near where all the connections were and waited to see if any of the water kind-of “flew away” from the seal then I knew I had a leak :( .
Congratulations!
All you have to do is connect everything back and your set!
Now go get cleaned up asap so you can go cruising.
Thank you to……
Krystal Boone for writing this for me while I was doing the work.
Devin for helping me with the install.
Scott Wise (for helping me with a couple things I was having problems with)
John (l2rtsiawd) for answering my questions when I called him… and for laughing at me when I figured out I had to drop the turbo to get to the back o2 housing bolts.
What are you doing still reading? GO DRIVE AND ENJOY YOUR NEW EXHAUST!
Title on top ?
man i sure dont recall going thru all that for my o2 elim d/p
it helps to remove a/c fan -- ( it may have been in there i just skim read it. )
hmmm...this wont work with a t25 but what *I* would do with a 14b/16g is:
dont drain anything, we won't be taking the turbo off, just the exhaust housing. Take out the drivers side fan. Disconnect the battery, unplug the o2 sensor(follow the wire to the left side of the block) and move the wire out of the way. Remove heat shields(both uppper and lower). Unbolt downpipe. Find the bolt that holds the v-band clamp together. The vband clamp is in the middle of the turbo, its about a 1/2 inch wide metal ring. Take the bolt out(dont lose it!!!) and take the clamp off.
Remove the 3 bolts and 1 one stud(if you havent replaced it with a bolt yet) that hold the turbo to the manifold. If you are lucky, with enough pb blaster and some vice grips you can just twist the stud out. Otherwise, you might have to slot the top of the bolt with a dremel and a cutoff wheel and use a screwdriver. Once the bolts are off, the exhaust housing/o2 housing should be free to move. Carefully move it away from the turbo and dont hit the turbine wheels. Now with the the assembly out of the car, it will be easy to seperate the o2 housing from the exhaust housing. Use lots of pb blaster if stuck. If you are gonna reuse the old o2 sensor, be prepared to cuss alot. I find it easier removing it with the o2 sensor off the car. Get a friend or a clamp to hold the o2 sensor housing. Get an o2 sensor socket (or 22mm wrench?) and use ALL your might to break that sucker free. A very large breaker bar will help. Install should now be the reverse of removal.
I dont follow you on the top part. The bottom part I got yah 110%.
This is an install for a turboback o2 elim exhaust install on a STOCK turbo. Thats going to be the title of it and I thought I did the title.
Dam.... loosin my mind.
the method I posted wont work on the t-25, but will work on a stock 14b(or a 1g/2g with a 16g). On the 14b/16g, the only thing the holds the exhaust housing to the turbo is a band clamp. The o2 housing is connected to the exhaust housing, and is difficult to remove with everything on the car. If you just take off the exhaust housing/o2 housing, itll be easier. For the 1st paragraph, its basically the same as what you wrote, except for taking out the bolt that holds the band clamp together.
