2G Radiator fans always on
BillDCat
39
Dec 15, 2002
Tucson, Arizona
Hi guys,
I just finished putting my car ('95 GSX) back together after a transmission swap. I finally get the bugger started, and immediately notice that the radiator fans are on. They stay on, and dont shut off. The coolant guage works - it goes up as the car warms, and rests a little below half way. The ambient temp here is like 30 degrees.
I figure that I probably pulled a wire from its connector or something, but I can't see any loose wires. What sensor could I have disconnected/could be defective to cause this?
Thanks in advance.
-Jon
Fixed. The douche who owned the car before me left the engine wiring harness a rat's nest of electrical tape and poorly spliced wires. An hour of hunting, and 5 minutes of soldering took care of it.
I've always wondered whether you could wire up one fan to run on low speed until the fan thermoswitch tells it to quit - regardless of whether the ignition was on or not - kinda like a honda (I know - I know) - & not run the Battery down on a hot day...
Today's project update... Well if you remove the female spade lug that has the Blue wire with Black stripe from the connector frame under the Radiator Fan Relay - then add a wire to that lug with a 20 Amp fuse - I used an aftermarket mini-fuse (same as stock) block with 14 gauge wire & go straight to the Battery terminal with the other end of that wire. Replace the lug into the connector frame of course - The Radiator fan will then run whenever the Coolant Temperature Switch at the bottom of the radiator closes (on 185F - off 172F) - REGARDLESS of whether the Ignition is on or not. Slight safety hazard as it will cycle a few times after you cut the car off if it's warm outside - but there is a sticker telling you it comes on automatically! This will be a bigger deal in the Summertime here & anywhere South of S.C. IMO. I have the small hole in my Thermostat so the Coolant can flow via convection till it cools.
Update to the update - In addition to the Radiator fan coming on when the car is off & the Temp Switch says the coolant temps are above 185 (my desired "Mod") - IF you have the AC button in BOTH FANS continue to run when you cut the car off & NEVER STOP - unless you let the AC button out. That "feature" could come in handy - but it could run a Battery down too... I told you guys I'm no electrician!
my fans are always on. Both of them never turn off, except when the car turns off. It is a nice feature I got to work.
That set up would be a little harder on the Alternator & Fans & you are missing the Temperature spike immediately after you cut the motor OFF (the highest Temp point!) - My radiator (passenger side) fan cycles per the Coolant Temp Switch whether the engine is on or off
(like a freaking honda - I know - I know..)
  • For sale GVR4 Rare HKS Hi-Flow Intake Kit
    Rare HKS Hi-Flow Intake Kit $175 + shipping & paypal fees* For GVR4, but can also use on 1G *...
  • For sale 1g NEW Fidanza 6 Bolt AWD Flywheel
    NEW Fidanza 6 Bolt AWD Flywheel $250 + shipping & paypal feesYou must be registered to see...
  • For sale 2g Dejon Intake ( recirc )
    2G Dejon Intake ( recirc ) $90 + shipping & paypal feesYou must be registered to see...
  • For sale 1g 1G Sun Visor Set
    1G Sun Visor Set $60 + shipping & paypal feesYou must be registered to see element.You must be...
  • For sale 4G63 Black Top CAS
    Black Top CAS $90 + shipping & paypal feesYou must be registered to see element.You must be...
