How to properly break in a turbo? [Merged 5-8]
onegee
555
Jul 27, 2002
., Asia
so just wondering, what is the PROPER way to break in a new turbo? i'm buying a used turbo from a 3g guy w/ 1k miles on it and want to know if he properly broke it in or not...and if he didn't what would be some of the problems? ### reply with any insight and information..i'd really appreciate it..thanks
From all the threads I've ever read on this subject, the consensus seems to be that there's no break-in period required. Only when first installed, crank the car without starting it for 5-10 seconds to allow oil to get into it. And some don't even believe it's that important. IMO, I don't think you have anything to worry about.
if you crank it w/o starting do short bursts with time in between. you don't want to burn out the starter do you? =)
You won't burn out the starter from running it for 10-15 seconds. How do you think people do compression tests? :)
5 minutes after installing my Green I was hitting 20psi out on the streets. Though the problem with that was it was raining, and the rear of the car didn't like staying put when all 4 wheels were spinning at the top of third gear :D
just a precaution. btw. i cranked mine for less than 15 and the magnetic switch burned out that night. most manuals i've seen (don't know if the factory one does as well) say to run the starter for less than 15 consecutively.
All you need to do is spin the engine over with the crank sensor off so the engine won't fire, but just do it long enough to get the oil gauge to move. Once it moves pllug the crank sensor in then run the engine. Basically, get some temps in it and check for leaks. Beyond that take it out and spool it carefully to see where the controller is set. After that have fun.
I don't think there really is a break-in period for a new turbo. From what I heard most turbo's are tested/heated from the factory and that's why the don't need to be broken in. I don't know if that is true though.
Before i get my new star performance stg II turbo kit, im trying to gather facts about everything. Anyone know how to properly break in the turbo system before you can unleash h3ll on the world? OMG
ive heard of people changing their oil right after a 30 min warm up just to be sure to rid an possible metal shavings or whatever. and then again at 500. do you think that is a little excessive?
Just "prime" your car like Jim said, then drive for the rest of the day on low boost, then turn it up the next day.
I read somewhere that you shoudl crank it for 30 secs after disengaging the ignition system. Is this true and if so, how do you disengage ignition? Just take out the plug wires?? because I know you car isn't going anywhere without spark.
Thanks,
Jake
...Seems easier to just take the plug wires out. Nevermind, I forgot you were installing a turbo. So I guess taking out the seats isn't that much harder. Whatever, I guess just personal preferance.
