2 sidemounts?
are you referring to the dejon tool dual sidemount setup? if you are, i hear its really quite useful. It helps w/ the sleeper look but then you should get rid of the stock foglights so they don't block airflow. On top of that you have to get rid of your ABS (if you have it) to accomodate the piping for the dual sidemounts. There really isn't any performance benefits to using the dual sidemounts over the fmic except you get more flow to your radiator.
my friend sean just welded 2 sidemounts together and uses it as an FMIC. I know he'd get better performance with an actual FMIC, but hey it was a cheap lil solution, and he just ran an 11.9 not to long ago. So take that for what its worth!!!
