notsofastdsm55
- 61
- 0
- Jun 20, 2007
kailua,
Hawaii
I am wondering, can g/rev be converted to psi/bar? It would make tuning a little bit more simple if you can just look at you're logs (provided you have a map sensor) and go from there, not that it is difficult but it would help my friend out a lot! as he can't log g/rev at the moment. I think mmcd offshoot does though I'll have to look into it!
factory in-dash boost gauges do - The ECU drives the factory gauge directly from the g/rev value it calculates from the MAS sensors (intake temp, baro, and volumetric airflow) and engine RPM. Also, users of DSMLink will be familiar with the loggable value "BoostEst". The value of this parameter is also directly derived from the ECU's calculated g/rev value.
