2G External Oil Cooler install
Thanks to Mike (Spoolin98) for his generous help when I was searching for my setup. If you are a 1G 6 bolt, 1G 7 bolt, or 2G 7 bolt and have done similar, please feel free to PM with your pictures/setup and I will include it here. I would like to create a comprehensive install guide for all models.
This is for a 6 bolt in a 2g
www.jnztuning.com - 1990 oil filter housing ~$90.
PN# MD132912 (thanks for reminding me xteekayx)
Learn to port your oil filter housing here
AN PLUMBING.COM Earls performance products Hose ends Hose,Adapter fittings
21908 - 19 Row Heigh 5-7/8". Face width (Between tanks) 4". Fitting Centers 5-1/8". Body Width 8-1/4". Thickness 2". $115.49
800108 - Swivel-Seal Straight Hose End - $7.99 x2
809108 - Swivel-Seal 90 deg/ Tube Hose End - $19.99 x2
9919EFJ - Metric thread male to AN adapter male - $7.99 x2
306008 - Auto-Flex Hose (Use Swivel Seal, Auto-Fit or Auto-Mate Hose End) - $35.82
Total cost was $313.32
Spoolin98's (Mike) setup:
Here are some pictures of my setup, which is identical to Tom's, except I used ss line I already had instead of purchasing some from anplumbing.com. I also used the stock crush washers between the part number 9919EFJ and the oil housing itself, which I also ordered from JNZtuning.
