lovin that phantom knock
Hiitman
482
3
May 12, 2004
Colorado Spring, Colorado
so im getting knock in vac while cruiseing in 5th gear....just making sure i can set the knock tps until i can check/replace the sensor on thursday
heres a 3rd gear pull from a few minutes ago. really running 15psi. is that a/f instability normal? theres that knock again too. ive pulled timing and it still doesnt go down. anyway. need to do an exhaust leak test. did a boost leak test (used a bike pump? to compress) and it only leaked through the bleeder hole in my mbc. anyway. is that a/f ratio ok?
forgot log
heres a log from a few minutes ago with the knock tps set. after the run i raised the fuel sliders from 4k up +1. i still need to get a timing light and check base timing tho.
