EGR Block-off, 2g 6 bolt, drawing inside, few questions
TSG59_Steve
717
Jun 27, 2006
Dunlap, Illinois
That's the Taboo vacuum diagram. I can just run a catch can there? I don't need to route it back to the intake or anything? I think it looks wrong and if it is it should probably be changed.
Also according to the taboo info I can run the boost gauge off of "P" on the throttle body?
Something looks wrong with that diagram but I cant figure it out.
But, you can use the P port of the throttle body to run your boost gauge. Im not 100% sure if it will show vaccumm though. I heard somewhere that it will only show boost. But it is worth a shot.
With both sides of a catch can plumbed into the VC, it will not function. You have to have a vent to the atmosphere, or into the intake, from the catch can.
With both sides of a catch can plumbed into the VC, it will not function. On the other hand, You have to have a vent to the atmosphere, or into the intake, from the catch can.
So even the way you have it drawn won't work? Or if I vent it, that will work?
Notice that Locke added the "To Atmosphere" in the photo he posted. If you notice in your first photo you posted, the air (aka blow-by) doesn't actually go anywhere from the valve cover. The valve cover needs to vent air out. Your first photo does not indicate that; the valve cover just vents back into itself, which means nothing in terms of relieving the crank case of blow-by.
Either have a hose that recirculates back into the intake pipe (from the valve cover), or have an extra hole/exit port on the catch can so the blow-by can be relieved from the system into the atmosphere. This thread and this thread also have some solid info if you care to read some more. :)
Thanks guys and sorry for the noob question. I read through tons of threads on catch cans and everything but didn't see anything about setting it up like that.
Thanks again,
Steve
  • Wanted 1g Chassis harnes fuse box
    • 92AWDHX40
  • Wanted 4G63 WTB Evo 560cc injectors or 450cc
    Im looking to pick up a set of evo 560cc injectors or possibly a set of 450cc injectors if the...
    • eclipsemf
  • Wanted 1g Looking for pn MB522081
    Looking for a factory 1g double din radio bezel pn MB522081
    • Kgilis
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
