This bushing kit was purchased from EnergySuspensionParts.com
When purchasing polyurethane bushings online it can be confusing without pictures that are application specific to your vehicle. Below you will find a picture of each part included in the kit just as it came in the box. Each picture has the name used on EnergySuspensionParts.com, the part description found on the box (part box), and the reference term used in the Hayne's Manual (hayne's). The Hayne's manual reference can be helpful in determining what bushings you actually need and how much labor is involved before you purchase. Additional notes on each bushing can be found below as well (note).
* Click on the links below for installation information for that specific bushing. *
Front Control Arm Bushings
Part Box: 5.3108 Eagle Talon Frt Lwr
Hayne's: Control Arm
Note: The control arm bracket bushing is not included. Do not remove.
Rear Control Arm Bushings
Part Box: 5.3109 Eagle Talon RR Axle
Hayne's: Rear Axle Assembly
Note: Rear axle must be completely removed from vehicle.
Subframe Bushings
Part Box: 5.4103 Eagle Subframe Moun
Hayne's: Steering Gear (Subframe)
Note: Top washers not used in original configuration.
Front 19mm Sway Bar and End Link Bushings
Part Box: 5.5107 Eagle 19mm Front Sta
Hayne's: Front Stabilizer Bar and Bushings
Note: End link bushings not used with ball joint style.
Rear Track Arm Bushings
Part Box: 5.7106 Eagle Talon Track Ba
Hayne's: Lateral Rod
Note: These are not control arm bracket bushings or center member bushings.
Tie Rod End Boots
Part Box: 9.13103 Tie-Rod End BT O.E. ST
Hayne's: Tie Rod Ends
Note: Not used if completely replacing tie rod end.
Extra Prelube
Part Box: 9.11110 3 Pack Formula 5 Pre
Hayne's: n/a
Note: Not necessary, but nice to have.
Subframe Bushings
Tie Rod End Boots
Extra Prelube
Hayne's: n/a
