Bypassing 2nd oxygen sensor question!!!!!
cisco5311
81
Jan 5, 2007
Hiram, Ohio
I really don't like seeing the CEL
I've read the tech articles about doing this, I've got everything that is needed to do it but here is my question
do i wire in the capacitors and the resistors right into the oxygen sensor harness and leave the sensor attached?
or do i wire in the capacitors and the resistors into the harness and totally cut off the O2 sensor??
thanks in advance!!!!
chris
Check the Tech Guide, there is a step by step write up on it. I have had mine for about 2 months - total cost less than $7.
So after I did the mod I was still gettin CEL's but they are different ones THIS FIXED THE O2 sensor malfunction!!!!!!!!
I luv you guys
now i need more help with these other codes it's spitin out.................................
