Need a wiring diagram
the_skin_eater
213
Sep 2, 2006
Vail, Colorado
I cant find one anywhere...I need one for the engine bay. I have extra wires and such around the alternator, and need to make sure others are correct. That and I found one on the driveway I need to reconnect.....
I looked, but havnt found a posted diagram. I dont have an owners manual either. I do have a chiltons, but I didnt really notice anything in there, unless I missed it.
This is the best i can do. I'll look for a diagram around the alternator. Sorry. Also what model 92 is yours? Early/late 6bolt/7bolt.
engine bay
Awsome. Thanks.
And Im not sure..I think its the 6-bolt. I really dont know. Im new to DSMs, and mine needs a lot of work so Ill figure it out here soon.
I got them from the manual cd.. Its photocopied from a factory service manual.. On ebay, 7 dollars shipped.
(reviving from the dead)
Soo if I were to be rewiring an alternator located at the back of the block, which direction do I go? IE would I back track the wiring towards the passanger side of the car and back to the battery, or back to the firewall and then over to the battery?
I'm going to be upgrading some wires and cutting out worthless ish like fog light harness and such.
Also, if I see this correctly, the B31 is a coolant temp switch that is ONLY used for the A/C circuit? If so I could remove it, plug the hole, and remove the wires with no effect to anything else.
  • Wanted 6 bolt NT water pipe
    • chrisman287
