Resolved 2G ECU? Which ones will work
ok_opie
Jan 6, 2006
KC, Missouri
I have a 97 FWD M/T Turbo ECU, and a 96 FWD A/T Turbo ECU. I am selling them, but I don't know which years they will interchange with.
Everything I read says all 2G 95 thru 99 will interchange but are different w/EPROMs on some 95's. The main thing is will they function correctly is A/T M/T different and is the AWD FWD different. I would just hate to sell something to someone that don't work. Thanks
Solution
mdtalon901 said:
The 96 ecu will work on any 95 - 96 turbo, mt or at, that does not matter.
the 97 will work with all 97 - 99 turbo cars. mt or at does not matter.
In 97 mitsubishi switched the cas signal, that is why you would have problems interchanging them. You could use a 97 ecu in a early 2g, but you would also have to use the 97 - 99 cas. or vice versa.
You can use any 2g turbo ECU on any 2g turbo car. Yes the CAS signal is inverted, but the solution to that is to swap plug and injector wires.
If you want to use a 97+ ecu on a 95/96, swap plugs 1 & 4 with 2 & 3 and for smoother running do this injector rewire:
Green: Pin 1 is now 14
Green w/ yellow stripe: Pin 2, is now Pin 1
Green w/ red stripe: Pin 15, is now Pin 2...
The 96 ECU will work on any 95 - 96 turbo cars. MT or AT, that does not matter.
The 97 will work with all 97 - 99 turbo cars. MT or AT does not matter.
In 97 Mitsubishi switched the CAS signal, that is why you would have problems interchanging them. You could use a 97 ECU in a early 2g, but you would also have to use the 97 - 99 CAS or vice versa.
Stole this off a link from this site (dsmtuners)
1990
Inagural model year of the DSM.
Pop-up headlights.
Some high-end models had wheel covers.
All ECUs had EPROMs.
Front brakes change during the model year.
1.8L models have the 4G37 engine, all others have the 4G63 engine.
1991
ECU changes mean that 1991+ ECUs don't operate the 1990 tachometer correctly.
Most ECUs had EPROMs.
First model year with ABS available. ABS not available with limited-slip differential (LSD).
All high-end models had alloy or mesh wheels.
First year of the Galant VR-4 - 2000 sold in the American market.
1992
Non-popup headlights introduced on all models.
The first AWD Lasers were introduced.
Few (or no) ECUs have EPROMs.
ABS now available with LSD.
The engine changes from the 6-bolt version to the 7-bolt version in April.
Second and final year of the Galant VR-4 - 1000 sold in the American market.
The last year of the Dodge 2000GTX.
1993
"Big brake" 2-piston front calipers become standard on turbo models.
7-bolt engines are now standard.
No ECUs have EPROMs.
Diamond-Star Motors ceases to exist.
1994
All cars built to California emissions standards - there are no "Federal" cars.
The last year of the 1G car and the 1.8L NT models.
The last year of the Plymouth Laser.
1995
The inagural year of the 2G DSM.
Significant changes to the engine, body, and electronics.
New transmissions.
All ECUs have EPROMs.
Non-turbo models are based on the Chrysler 420A engine instead of the Mitsubishi 4G63 engine.
OBD-II becomes standard on DSMs, along with two oxygen sensors.
Mitsubishi begins using some substandard crankshafts, leading to crank walk on some 2G cars.
1996
The first year of the convertible Spyder.
The Mitsubishi 4G64 engine is offered, in the Spyder models only.
ECUs stop having EPROMs.
1997
Additional body changes from the 1995/1996 models.
Minor changes to the ECU code.
1998
After many years, Mitsubishi finally issues a recall on the AWD DSM transfer case.
1999
The last year of the 2G car, and of the 4G63/AWD DSM platform.
The last year of the Eagle Talon. Chrysler drops the Eagle marque.
LOL, wow, a moderator needs to fix that on the site.......
I just copied and pasted.....WTF
Yellow w/ black stripe: Pin 14 is now Pin 15
If you have DSMLink the injector swap can be done by clicking the 'invert CAS' option.
Solution
