2G front tweeter replacement
This is an easy way to fix/upgrade the front tweeters on your stock 2G infinity sound system. This is my second car and both have had blown front tweeters so I am assuming this is a fairly common problem.
Right now there are a couple of sellers on Ebay with Bose tweeters. Search on Bose Tweeters and you should find them. You are looking tweeters that are 3 1/8 inch.
From the ad that I bought from:
These tweeters are "New" surplus and have a 3 1/8" outside diameter and are used in many BOSE "direct reflecting" models. They were also used in BOSE "Interaudio" brand models, notably the "SA" models, where they were mounted behind an injection molded plastic flange. They are 4 ohms and have the plastic magnet cover on them, but are the same as the ones without the cover. They have the 8-32 threaded mounting hole in the backplate. The part number is 116088.
Pull your front tweeters, use a screwdriver and pry them up – be careful not to gouge your dash. Disconnect the quick connect plug. And look at the bottom of the tweeters. The grill is held on with four tabs. Use a screwdriver and pry them up. The grill is slightly too small for the speakers. Take a pair of pliers and spread the grill all the way around the outside, go slow and don’t spread too far, you can always spread it more. Try the grill on the new tweeters, when it fits on nicely, take a small hammer and tap the grill all the way around the speaker to make it fit nice and tight. Bend the four tabs down.
To protect your new speakers, I recommend that you solder a crossover capacitor to the red leg of the tweeter. Use a 50 volt 22 microfarad cap. This will only allow the high frequencies to pass to your new tweeter. Cut the original wires that go to the plug and solder the wires to the tweeter, red wire to the leg with the red dot and capacitor on the speaker.
Put the speakers back in the car – they sound awesome!
  • Wanted 2g 2g Hood latch support
    On the hunt for the support that holds the hood latch assembly.
    • jesse12345
  • For sale 4G63 Hallman ES Boost Controller
    Boost controller
    • jpturbotalon
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
