91BlackLaser
- 140
- 1
- Feb 13, 2006
Calgary,
AB, Canada
Just wondering what would be the best clutch for the fwd Laser. It is daily driven but does see the track on Friday nights.
98eclipseRS said:Get the 2600, adjust your pedal correctly, and have the system bled correctly and you are set to go. The 2100 won't last long enough at all on repeated launches. The 2600 feels slightly stiffer than stock for about a week untill you get used to it and then you are good to go. If you had an awd I would recomend the 2900. Just make sure to get the street disc a.k.a.-the organic one and an oem tob.
droppinbottom said:I would not reccomend the 2900 on a awd due to strain on the transfer case.
98eclipseRS said:have you ever used a 2900?? I didn't think so, the clutch puts preasure on the crank not the t-case. Idiots that can't launch their car are the cause for huge stress on transfer cases.
Sounds like some FWDers can't drive. I've had my 2100 on my car for nearly 3 years, making some decent power, and it's still holding strong.TRBOBLU said:I would get the 2600. I have seen multiple FWD's with bolt on mods toast 2100's after only a few months.
brygsx95 said:get the 2100 unless you plain on replacing ## tranny then go with the 2600. The 2100 holds just fine.
knighteclipse1 said:I have been told by a local DSM shop that a 2100 is best because anything stronger with a 7 bolt would make the engine crankwalk. Of course I don't believe this. But this is a very knowledgeable shop (very good reputuation) Why would this be said then?
98eclipseRS said:Because they are idiots, crankwalk is sssssssssssooooooooooo overdiagnosed. It is true that the added preasure the stiffer clutch brings does put larger amounts of stress on the crank and its bearings but if an engine is going to walk its going to happen regardless of what clutch you put in there. To the OP I promise you if you go with a 2600 you won't be dissapointed. I had a 2100 in my car at first and hated it. clutch pedal was too soft and like I said just would not hold up to the repeated launch abuse.
droppinbottom said:Yeah I guess you are right. I have never used one. My information comes from Lucas English of www.englishracing.net. He is probably one of the best dsm builders in the pacific northwest and when I was choosing the clutch for my car he strongly advised me against a 2900 for the very reason I stated. So I guess you are calling him a idiot since he told me himself that he quit using the 2900 due to having problems with the transfer case and that since he switched to a 2600 he has not had any problems. Go check out his site and you tell me if he knows how to launch a dsm or not. Maybe you should think before you start talking trash and calling people idiots.
Have you had any personal hands on experience with the clutch??? Yes, or no? I am not tyring to be rude but he said she said bullshit is what brings around all the horse shit you have to wade through on internet forums. I have personally helped install and driven/seen them driven on a daily basis a handful of awd dsms running 2900's and 500+whp and none of them have had a single problem and all would recomend the clutch to any serious awder.gridlyne said:I went from Stock to a 2100. I felt almost no difference. If I were to do it again, I would go for the 2600.
