Turbo bolt/washer ??
selser420
83
Apr 8, 2005
Detroit, Michigan
I just got new turbo bolts and washers from SBR. These are the spring washers that have a beveled edge and the 2 dots on one side. It came with 8 washers so I assume you use 2 per bolt. I was wondering which way they go on in relation to the bevel/dots and stacking them(assuming you use 2 per bolt).
Do they go like?
1 ----))
2 ----()
3 ----((
4 ----)(
5 doesn't matter
I have to bring up this post to verify. I just picked up these washers (MR187848) and the tech at the dealer told me both dots go up. I looked at caps and it looks like two dots are up but its hard to tell. Can anyone verify this?
Do they go like?
1 ----))
2 ----()
3 ----((
4 ----)(
5 doesn't matter
Based on the service manual, number 2 is the correct orientation for these washers (dotted-side of lower washer contacts the exhaust manifold, dotted-side of the upper washer contacts head of bolt.)
