How to program your keyless entry remote
This was giving to me by another dsmer and I decide to let everyone know how to do it. 1.Turn the igition off.
2. Ground pin 1 of the data link connector (black 16-pin connector under dash driver's side). Pin 4 of this connector is a ground, so placing a jumper wire between pins 1 & 4 will accomplish this. Grounding pin 1 tells the system you are getting ready reprogram it.
3. Close all the doors.
4. Turn the key to acc, then back to off. The power locks will lock/unlock. The system is now ready to be programmed.
5 Press a button on your key fob 3 times.
6. The doors will lock/unlock to signal that the codes were received.
7. If you have two keys fobs,press a button on the second fob within in 1 minute of pressing a button on the first one 3 times. Both must be programmed at the same time.
8. The doors will lock/unlock to signal that the codes were received.
9. Remove the connection between pins 1 and 4.
  • For sale 1g 1G Turbo Intake Kit
    Used 1G turbo intake kit. Fits on stock intercooler and uses stock BOV. Comes with the MAF and...
    • Badge023
  • For sale 4G63 Used FP 4G63 Turbo Manifold
    Used FP 4G63 Turbo Manifold removed from 1G Talon. Looks okay, needs a cleaning. Did not see any...
    • Badge023
  • For sale 2g Fiberglass Fenders
    2g Fiberglass fenders. Overall good condition. $50 + Shipping/FeesFor faster response Text...
    • 1SlowPOSEclipse
  • For sale 2g 97-99 Mpi relay
    2g. 97-99 Mpi relay. Many don’t realize the later 2g doesn’t use the same mpi as the 90-96...
  • For sale 2g 2g window moulding
    2g pass side window moulding. Rubber is in decent shape. Has one dent. Front plastic end cap...
