MAFT Pro Clarification - speed density and other options explained
Mike Licht
100
Aug 1, 2003
Clinton Twp, Michigan
I have had lots of questions and misunderstandings about the new MAFT Pro so I will try to clear up a few things here.
The MAFT Pro can operate in 3 different modes,
MODE 1 - AFC mode, it works just like an AFC it can be installed as is with no other items still using the stock MAF sensor (or a 2G for a 1G car) it will give a + or - 60% fuel adjustment over 14 RPM band at 3 different load levels in 1/2% steps. This gives it more capability than other products and room to grow over to more advanced levels, can also use the two things listed below under options
MODE 2 - Translator mode - Mode 2 will allow the use of a GM style MAF sensor like the original MAFT but still give the above tuning options, can also use the two things listed belowunder options
MODE 3 - Full Speed density. This mode will run the car without a MAF sensor at all like the old VPC. It is also fully tunable as in mode 1. To run this mode you will need a GM air temp sensor mounted in the uppipe and a GM or AEM map sensor. We have harnesses available to make installation easy. This mode also give full fuel control based on boost. Can also use the two things listed below under options
Options - There are two options for the MAFT the first is wide band controlled Air/Fuel tracking. With the connection of a wide band like an Innovate LC-1. You can specify a target air/fuel ratio for WOT conditions. The Pro will then monitor a/f ratio and adjust accordingly while going down the track. For example, if I want the car to run at 11.6 to 1 I specify that (I can pick differnet values across the RPM range) while going down the track if the car starts to get lean the Pro will add fuel if it gets rich it will take it away. For meth users it will lean it out while the meth is spraying. This is awesome. The unit is preconfigured for most popular wide band units.
The other option is closed loop boost control. You can add a harness and a solenoid and then specify whetever boost level you like and the Pro keeps it there. There is gain, TPS and other boost related controls as well.
Unit comes with full software and cable to connect to a PC for datalogging and programming if you do not wish to use the front panel buttons.
Keydiver also has a PRO chip that is available NOW that allows you to control ignition timing from the front panel when using the Pro making this a very complete tuning solution
So you can have fuel control, timing control, Closed loop Air/fuel control, and closed loop boost controller with full speed density if you like.
If you have more questions please post them here or call me at 586 790 4406
Mike
Jebus, I was unaware of the tunablility of the MAFT Pro. I am currently running a MAFT 1.3, with out anything but an AFC. Sounds like I will be going with this as a cheap solution to ignition control and speed density! :thumb:
User friendly how? It is an advanced tuning tool so there are lots of adjustments. It is very easy to use however and onc it is set up fuel tuning is two buttons on the front
Mike
Yes the code for the 3.5 and 5 bar sensors are already in the unit. There is about 100 units out there on cars now fastest one went 8.90 (turbo LS1 car) lots of Buicks in the 10's alreadt. I know of a DSM that made 720HP on the dyno just using this and a keydiver chip for tuning
Mike
There is quite a few DSM units out there now. Bob has one on his Stealth and drives it everyday My Buick starts runs and drives better than stock. The amount of adjustability make the drivability easy to get right. Some of the guys post on our message baord, Evo M had a MAFT Pro section some good info there
Mike
on the maftpro site it kinda seems like the logging capabilities are kinda limited, do you wish to expand?
It logs everything that the unit controls, air/fuel, boost, rpm, throttle position what are you after?
Mike
keep the infos coming,this is going to be my next purchase
Now correct me if I'm wrong, I belive I read that I can ditch just the Translator and get the Pro and hook it directly to my GM Maf... is this true. I don't quite want to bite the bullet for the speed density but it sounds like a more advanced way to tune than the MafT and AFC, atleast alittle more consolidated. Is the box of the Pro simular in size as the MafT? I know have my MafT mounted in my center console in the little hide away cubby and would like to mount this there in it's place.
More general info would be much appreciated.
Thanks
This is my next purchase too, so far though I cant find anybody that wants to talk about the thing, and eveyone I've asked about it knows nothing of it and dont know anyone that has one or has used one. Give us more info if you can. :dsm:
exactley, keep this thread up :thumb: i want to know more! someone on here must be using the map sensor function.
Thanks
You can ditch the translator and the sensor too if you get a Pro. It is a little bigger
Mike
What sort of info do you need?
Mike
Mike
How would it work if I didn't want to go full speed density right now?
I guess what I want is for someone to "sell" me on this thing. I would like to see more input from people that are using it. It seems like it was released and then everyone ignored it like it was a joke or something. A few big names using it would'nt hurt either, that would make some of us feel better about investing in it. So SELL this thing to me. :dsm:
My questions are.
1. Wideband LM1 control. What additional parts would I need to accomplish this.
2. Speed density. If I were to get MAFPRO and speed density, what parts would I need and how much would it be altogether.
3. How would I monitor all of this? Can I still use my Pocketlogger m550? Would I need a computer or laptop as well?
Currently I have MAFT, Pocketlogger. I can see the benefits this would be for me.
Also how would this work with Meth Injection system/
Thanks
George
44pirate said:
My questions are.
Thanks
George
+1
I'm running this same system and would like a package with cost on what it would take to do both of the options above.
Sorry for the long post, I also posted my same questions from my post above (post #16) and got this responce at the Fullthrottle forums.
Yes, the "Translator Mode" was built into the unit for this purpose.
There is no premade harness for this mode yet, since everyone has gone with speed density so far. The wiring connections are very straightforward, however.
You will gain a bunch of tuning capability, logging, AFR control, boost control, etc.
The box is a little bigger then the MAFT's
There are complete tuning controls for the injector size correction, etc.
Bob
so with this i wouldnt need my logger or a safc..? also does the wirings go all the way to the inside of the car..?
